I need to find a fuel filter like this:
![]() With the 5/16" threads on each end. I want to eliminate as much rubber hose from the fuel system as possible, and since I'm making new fuel lines anyway, I figured something like this would be a good option. Any ideas where a guy could find one? I'm having no luck at all.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Re: I need to find a fuel filter like this:
some tractors use them i will get a part from work tomorrow
also here is a holley one
http://www.holley.com/230606ERL.asp |
I want to say 481 maybe? Standard fuel injection filter for 90s chevy?
![]() Join Date: Aug 2011
Same as my 87' Buick Park Avenue 3.8 L
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
Just verified... 95 chevy c1500 with 5.7... Can get this filter at any auto parts store...
Not sure about the 5/16 threads... 5/16 fuel line = yes
![]() Join Date: Mar 2003
Look at the application for a later model ford truck, carbureted 460 engine. They weren't very large though
Its a very good idea to try and eliminate as many rubber fuel lines as possible. especially between the fuel pump & carb.
Senior Moment
![]() Join Date: Mar 2002
Looks just like the one on my 2002 Burb
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
While a 3/8 line (If I remember correctly) tube nut will thread into it, the flare will not seat and seal. These require an o-ring style fitting.
I am referencing Puraltor F33144, AC Delco GF652. Fitting multiple GM vehicles. |
![]() Join Date: Mar 2014
I've hard-lined into those filters, I seem to remember using some sort of adapter fittings. ( This was several years ago, the details are a bit fuzzy )
http://67-72chevytrucks.com/vboard/s...d.php?t=620707 |
![]() Join Date: Dec 2013
napa auto parts have them , its just a inverted flare in line filter , instead of nipples a little more money , but a lot safer and a cleaner look
#15 |
Excellent leads, guys! I'll check on some of these tomorrow.
Thanks, all ![]()
#16 |
Whatever you do don't give up and use one of those horrible glass ones.
A fuel-injection-era one might have the GM fuel disconnects. You can make those with the Mastercool set (though I do not have the EFI dies you'd need). Next thing to consider is even if its a normal double flare, is it a metric thread? Since you're making your own lines that's OK, same line, just different nuts. But it'd be handy to have them when you leave the parts store. Kudos on getting rid of rubber. I love knowing its all steel except for two little flex sections of a couple inches each. And braided steel line is still rubber hose (which I have in a car, and probably should swap out soon).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#17 |
#18 |
#19 | |
![]() But I'm still looking.
#20 | |
Some of them are plastic, so you get a grace period of a month or a year before they get brittle. I'm not saying every one will explode and kill you, but the only time an OEM ever used a clear sight glass on fuel it was tempered glass and physically mounted in a safe place with no rubber lines and generally in a completely rigid assembly of some kind. Steel's your friend. Heck, if it's a Q-jet just run the factory filter. It'll support 400hp at least. If it's a Holley or other, get something in all metal.
#21 |
yep on the glass filter being bad news. my cousin had one on a 48 ford coupe, it cracked and by the time he made it off the road and got the hood open it was up in flames. to each his own, but don't use these
#22 |
Great thanks for the advice guys. One more reason never to listen to the guys behind the counter of Advance Auto
#23 |
That's a good idea for a filter. Looks exactly like the filter that I put in my Toyota truck. I could definitely make something like that work. Just get two bolts for the filter. Drill, bore, ream, and counter sink to size. Reflare the fuel lines and done! Definitely going to look into it. Great idea Pritch.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
#24 |
OK maybe I over thought this through. Lol ideas are flowing
