Old 06-13-2014, 07:02 PM   #1
tismy55
Front Radiator support
How do you remove the front Radiator support bolts that bolt to the frame? I have the nuts off but the bolts will not come out.Need Help
tismy55 is offline   Reply With Quote
Old 06-13-2014, 07:18 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Front Radiator support
put the nuts back on and tap the bolts loose.
They are probably rusted to the radiator support after all these years.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-13-2014, 07:25 PM   #3
tismy55
If they are rusted to the support what then.
Old 06-13-2014, 07:27 PM   #4
LostMy65
LostMy65's Avatar
If you have to hit them hard enough you ruin the bolts, you can get new aftermarket ones.
Old 06-13-2014, 07:46 PM   #5
tismy55
who sells aftermarket bolt kits with the rubber bushings,washers etc.for the support. I have seen cab mount and bed bushings but not radiator support bushings.
Old 06-13-2014, 07:50 PM   #6
LostMy65
LostMy65's Avatar
http://www.classicparts.com/1960-68-...ctinfo/78-625/
Old 06-13-2014, 08:06 PM   #7
tismy55
I appreciate your help. I ordered a set .Thanks Lewis
