Old 06-21-2014, 11:49 PM   #1
woody82
Gas gauge voltage
My gas gauge is not reading properly.I hooked a hot wire from battery to the spot on the fuse box turned on the key nothing happened but maybe it went even more past full .I checked the voltage from the wire that goes to the gas tank It reads 5.3 volts. is this normal or should it be 12 volts?
woody82 is offline   Reply With Quote
