Old 06-20-2014, 01:00 PM   #1
Bigdock
Brake booster question
I got a 64 gmc I've finally got all my Porterbuilt front end but together with disc brakes now I'm looking to buy a new brake booster and master cylinder together I have disc in the front and drums on the rear with a mostly stock 305 v8 everybody is telling me to get one of a 81-87 c10 but I'm looking for something new with booster master cylinder and prop valve like maybe a universal kit I'm getting the bracket from captain fab thanks for the help
Bigdock is offline   Reply With Quote
Old 06-20-2014, 01:26 PM   #2
tincan1966
tincan1966's Avatar
Re: Brake booster question
Try MBM power brakes, they make a bolt on assembly with no adapter bracket needed. Several other companies make kits, too.
Or just buy new parts instead of salvage for the 81-87 application.
I personally NEVER reuses salvage yard brake parts, but some do.
tincan1966 is offline   Reply With Quote
Old 06-21-2014, 01:18 AM   #3
Captainfab
60-66 Nut
I don't think there is much difference in the universal booster, master, prop valve assemblies from CPP, POL or ECE. I would go with who ever has the best customer service.
I have yet to see an aftermarket booster with a mounting bracket that does not require drilling holes to bolt up to a '60-'66 truck firewall. Unless it is a replacement for an original booster. But then you must have the original mounting bracket and wedge.
Old 06-21-2014, 08:57 AM   #4
Bigdock
Yea captain fab I'm going to use your bracket but I think I'll probably go with the brothers kit or factory components from my local parts store for 81-87 c10 the only think I haven't searched yet is the jd3 and jd5 brake codes for the 81-87 could possibly be jd3 with 1" front rotors and jd5 is 1.25 front rotors
Old 06-21-2014, 11:23 AM   #5
donthekawguy
donthekawguy's Avatar
I'm going to use a new MC/booster from a 75. I don't like the look of the plastic MC on the newer models. Orielly has them for around $150 and it includes the push rod. I got 75 1/2 ton parts from the wrecking yard (rotors and calipers). I rebuilt the calipers and lucked out with the rotors, they look like they were replaced within months of the truck being scrapped.
66 shorty
donthekawguy is offline   Reply With Quote
Old 06-21-2014, 11:33 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
For me to use the brake booster from the 73 to 87 trucks I had to moify the brake rod. Bascally cut the rod and weld a sleeve to use the stock brake rod from the 65. The eye hole is differnt and the rod needs to be longer if I can remember right.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-21-2014, 06:02 PM   #7
BLUE66C10
I used the CPP setup. Fit and finish perfect, all the hardware you could need and more, comes with adjustable pushrod and prop valve too. Only had to drill two holes.
Cost about $239 plus freight. I have been buying CPP stuff from FleaBay instead of direct from CPP because it ships faster and it seems like customer service is better when PayPal and Ebay are breathing down their necks.
Truck Shop has a pre-bent brake line kit for this conversion for less than sixty bucks that fits GREAT. I had to get two reducers from the local hardware store to adapt the lines to the stock tees, but other than that it was flawless.
BLUE66C10 is offline   Reply With Quote
Old 06-21-2014, 11:38 PM   #8
Bigdock
Yea blue66c10 that's a good looking setup I had looked at cpp but wasn't sure of the quality I have there drop spindles and had to modify control arm and spindle for clearence think that's what I'll go with and use captain fabs bracket instead of drilling two holes I'll look on eBay do you remember what size and single or dual action?
Old 06-23-2014, 08:52 AM   #9
BLUE66C10
It was the 9" single diaphragm booster. I have noticed that there is not a lot of reserve boost (I have a bit of a cam) but it seems to stop very well, and the adjustable push rod helped to work through the normally spongey-soft GM brake assist and give a good pedal feel.
Old 06-23-2014, 09:29 AM   #10
Bigdock
Thanks blue66c10 for the help I found it on eBay probably order this evening did everything come assembled? I'd really like the paint the booster black so it kinda blends in a little better
Old 06-23-2014, 10:10 AM   #11
BLUE66C10
Yes, it was all assembled...kinda of a shame to paint that pretty yellow cad plated booster black though IMHO...But I doubt that the warranty will be affected if you do paint it.
