5.3 starter wiring
My starter has 2 large terminals, I know the small is the purple but which lug is batt hot? Why have 2?
![]() Join Date: Sep 2005
Re: 5.3 starter wiring
should only bee one big lugg
#3 | |
Boosted Member
You need two, because the purple wire activates the starter relay/solenoid, and the big one supplies the large current load to the starter. There is no ground, because the starter grounds through the engine block.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
2large, plus the purple 3 total. Is this the external ground?
there is no external ground.... bolting the starter to the motor is the ground.
go ahead and ground that 3rd connection... you will see what 700 cca looks like first hand.... do not put any grounds onto that starter or those lugs... it will end badly for you!!!!
Ed will be known as the Tiger Woods of the integration business |
can you post a picture of the starter? that will help us to see what you have i mean you should have on1 bug lug for battery one small for purle and other lug should have strap or something feeding the starter motor it self
Boosted Member
Here is something I whipped up quick. Hopefully this helps.
That's it only no nuts so it just looks like 2 lugs
ah. Then you have the rare Female starter.
I know I should not have, but we all have to admit, I did snicker a bit. Looks like wasted income said it best. Best to ask questions than to make Xmas like sparks in mid summer.
