Old 07-01-2014, 11:28 AM   #1
slepysal
slepysal's Avatar
L6 ignition coil question
Looking for some help here. Can some one post a picture of the wiring on the coils (+) side.
I have only one wire coming off of the starter.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-01-2014, 12:38 PM   #2
jtrichard
Re: L6 ignition coil question
can you put up a pic of your eingine compartment so we can see just what you have
jtrichard is offline   Reply With Quote
Old 07-01-2014, 01:26 PM   #3
1963c-10
1963c-10's Avatar
See if this helps any. Shows both HEI and points. Points will be white and pink wires to the coil
1964 Short bed trailer
Old 07-01-2014, 01:58 PM   #4
slepysal
slepysal's Avatar
Right on thanks !!!
Old 07-02-2014, 01:08 PM   #5
jtrichard
63 c10 am i missing something.... WHY the yellow wire from the "R" ter. to HEI ????
Old 07-02-2014, 01:27 PM   #6
1963c-10
1963c-10's Avatar
I am no electrical expert by any means....just a diagram I've had on file and have used. I'd pose the question in the electrical section and see what they say. This diagram's been on the forum for awhile and was one I stuck a "sticky" on so I could access it.
Old 07-03-2014, 12:49 AM   #7
jtrichard
it could be a major PITA if you were to lose continuity on the pink (ING.) wire as it would "RUN" while you were cranking then as soon as you got off the starter it would die
