Brake signal for trailer tow controller
Guys, I have a 1972 GMC C20 that I want to install a brake controller for the electric brakes on my trailer. Where is the brake signal? Any pics, video and/or instructions? I can't find anything on the search fuction, maybe we need to ban it from this site, lol. Thanks
![]() Join Date: May 2010
Re: Brake signal for trailer tow controller
Not sure what brand brake controller you are using, but this may help.
http://www.pirate4x4.com/tech/billav...ng-generic.pdf |
im confused? what do you need?
hes needing the brake light signal for the brake controller. it uses the brake light signal to determine when to apply the trailer brakes.
look for the brake light switch on the brake pedal and tap into that wire. while your down there make sure its adjusted right so that it turns the lights and signals the controller at the proper time. as in turning the brake lights on before the brakes start grabbing.
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
#5 | |
Ok, gotcha. I thought I already used that light switch under the dash but I didn't check it with a test light. I'll check it this time with a test light to make sure it turns on when pedal is pressed and that its adjusted right. Thanks.
![]() Join Date: Apr 2005
Should be a white wire, the orange wire is hot all of the time.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
glad to help!
