Short Fleetside Braces
I tried to search this out, but had no luck - so please bear with me.
Don't the four (bolt-on rod) side panel braces mount to the Fleet side bed's cross-sills from the inside of the sill's channel with the sills mounted so the brace's mounting holes are on the forward (cab) side when installed? Thanks... rg |
![]() Join Date: Mar 2005
Re: Short Fleetside Braces
I have a '64 longbed, and that's the way mine was mounted from the factory. I moved my bedfloor up, so I had to change it from the stock configuration.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
I brought mine up 3" as well - so in addition to trying to remember how these go in, I have to figure out if another 3" of length will do (or what will) with the angle on each.
Thanks! |
