Old 12-11-2014, 11:32 AM   #1
Nordic
Nordic's Avatar
E brake cable
I just swapped to a Camaro rear end with drum brakes in my 58 long bed, I am able to reuse the passenger side rear cable but the driver side needs to be longer because it goes in the rear side of the backing plate. What is any body using with the stock e brake set up?
Nordic is offline   Reply With Quote
Old 12-11-2014, 03:50 PM   #2
Russell Ashley
Russell Ashley's Avatar
Re: E brake cable
When I converted my last truck to 4X4 and raised it I needed a longer e-brake cable for one side. I had a longer one made at Inline Tube. It didn't cost much and and looked exactly like the original except the length. When I re-did the emergency brake setup on my current truck I got the cables from Control Cables. Both places were easy and friendly to work with.
Russell Ashley is offline   Reply With Quote
Old 12-11-2014, 07:12 PM   #3
mr48chev
mr48chev's Avatar
Re: E brake cable
Two good suggestions. Another thing you might look into is having a local rigger for sailboats make you a new section of cable to replace the actual cable that will be the right length and work in your housing. You would have to take your cable to the with measurements but they may or may not be willing to do it. Or you might have a short section made up with the right ends on it to lengthen the cable that is too short.
My ongoing truck projects:
Old 12-12-2014, 01:46 PM   #4
solidaxel
solidaxel's Avatar
Re: E brake cable
Control Cables Inc has made me three sets to my specs and they will match anything or length, very easy to work with
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-14-2014, 04:04 PM   #5
53 randy
Re: E brake cable
I did the same, I went with lokor,[spelling] cut to length, works great. 53 3100
53 randy is offline   Reply With Quote
Old 12-15-2014, 01:18 PM   #6
lower50's
lower50's's Avatar
Re: E brake cable
Yup Lokar universal emergency brake cables just cut to length
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
