new speedometer
Hi I am doing a resto on my 69 gmc and have taken the 3 speed manual out and put in a 5 speed from a 92. I have seen that you can buy a electric converter to cable thing ,that is too much money for me so i was thinking of a new speedometer that icould fit into the existing space.What would be the best and easiest gauge to buy to fit my applacation
![]() Join Date: Mar 2012
Re: new speedometer
look up a GPS speedo,
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: new speedometer
http://67-72chevytrucks.com/vboard/s...d.php?t=512751. Read, theres two members on that who you would contact for parts if interested...
Re: new speedometer
What 5 speed did you use? What parts d oh d you need and any advice? I have a 70 gMc with a 6 and want a 5 speed.
Old member
Speed hut has GPS speedo that will fit into the factory cluster. I love mine. I put there whole cluster in the 71. All there is is a hot wire and ground and hook the lights into the cluster lights. No cables to hook up to transmission nothing doesn't matter what gear tire size you run it's dead on. You don't even have to calibrate it.
![]() www.speedhut.com ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: new speedometer
Ok I am officially amazed by the speed hut site. I love being able to shop without having to call or email for a price!
Old member
I've had mine now almost 2 years with no regrets! The GPS is slow sometimes coming on but it is dead on when it does. All the gauges work great and they light up nicely at night also. I have been thinking about selling this cluster since I installed the LS motor to buy a can bus set to hook up to the ECU directly.
Re: new speedometer
Andy: Thanks for the info on the gauges to bad iam so far a away or maybe i could buy the gauges from you
#9 | |
Old member
![]() Quote:
