Old 07-17-2014, 03:30 PM   #1
BrianG
BrianG's Avatar
Help finding thread for side mirror hole locations
I once saw a thread where someone added some actual dimensions to where the assembly manual shows the reference locations for installing the side mirrors on a 69 C10. Can anyone help me to locate that pic/thread. I've done my searching (A LOT) and cannot find this thread. I have the assembly manual, but I need to know where to start. Also, according to my assembly manual, it looks like the top two holes are parallel to the door body line. However, seems like on doors that I have seen, this isn't the case (factory holes) can anyone comment on that?
BrianG is offline   Reply With Quote
Old 07-17-2014, 04:52 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help finding thread for side mirror hole locations
Are these the ones you have? My post in this thread show the ones on my '69...
http://67-72chevytrucks.com/vboard/s...d.php?t=350011
LockDoc
Leon
Old 07-17-2014, 05:32 PM   #3
davepl
davepl's Avatar
I would not recommend just drilling holes. I put backing plates on all of mine so my holes have a good solid 1/4" of material that I tapped (1/4-20 in my case). But mine are Sr mirrors that probably take a lot more force.
I'd still put a plate on the inside if you can though, not just washers. But it'd have to be formed to the door maybe in that location.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-17-2014, 06:20 PM   #4
SS Tim
SS Tim's Avatar
What mirrors are you installing base or other?
SS Tim is offline   Reply With Quote
Old 07-17-2014, 09:38 PM   #5
BrianG
BrianG's Avatar
Thanks, I do have the plate's for the inside. So I am probably good as far as one hole relative to another, but I nee the stating points.
Old 07-17-2014, 09:38 PM   #6
BrianG
BrianG's Avatar
Stock mirrors for a 69
Old 07-17-2014, 09:41 PM   #7
BrianG
BrianG's Avatar
LockDoc
Thanks LocDoc. That does help some. That isn't the thread that I was thinking of, but it gets me relatively close.
The doors that I'm using had something like the camper mirrors that mounted on the longer brackets that were spread all over the door. I'm trying to go back to the style in the thread that you posted.
Old 07-17-2014, 10:27 PM   #8
SS Tim
SS Tim's Avatar
http://67-72chevytrucks.com/vboard/s...27&postcount=7
His hole dimensions match an example door I have.
Sounds like you are going off the assembly manual's pages that show the mirror located fore and aft from station 15 and vertically from waterline 35.
Old 07-18-2014, 09:44 AM   #9
BrianG
BrianG's Avatar
Thanks, I think this will help. Yes, I have the Assembly Manual which references those lines you mention. Although their location is hard to really come by.
