frame painting question
Im about to take off my bed. I want to just sand blast it at my dads work, but the rust has pitted the frame a good amount. should i just grind it(id rather not) or can i sand blast it then bondo over to smooth it out then put the outer layer of por 15 on.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: frame painting question
I used one of those stripper discs on my drill then a grinder then lastly I did the wire wheel then I primered with rusty metal primer and two top coats of rustoleum gloss black
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
sand blast is about the only way to get in the pits.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
If the pits bother you that bad after sandblasting and epoxy coating you can sling some mud on there. Don't use gloss black as your top coat though. Rustoleum Semi Gloss looks factory for the frame, undercarriage, and engine bay/firewall and is very durable. Whenever I'm at a car show and I look under the hood to a glossy engine bay it makes me wanna cringe.
You gotta have fun while you're little!! |
