Old 07-29-2014, 09:35 AM   #1
cajun chevy
cajun chevy's Avatar
ECE drop spindles, 15x 8 rim rubs control arm
Just installed 2.5" ECE drop spindles on my 72' c10 2 wheel drive and when I installed my 15" x 8" rally it hits the lower control arm.
My question is there a wheel spacer available so it won't rub on the control arm or should i try something else.
cajun chevy is offline   Reply With Quote
Old 07-29-2014, 09:48 AM   #2
blazer2007
Re: ECE drop spindles, 15x 8 rim rubs control arm
I use the 15x7 rally
blazer2007 is offline   Reply With Quote
Old 07-29-2014, 10:05 AM   #3
cajun chevy
15 x 7 front, 15 x8 back?
Old 07-29-2014, 10:29 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Or trim the lower a-arm "gutter".
This is a known issue with 15" wheels with more than a 3.5" backspacing.
Lots of threads about it on this forum.
Keith
Convert to disc brakes.
Old 07-29-2014, 12:17 PM   #5
tommyd241
tommyd241's Avatar
http://67-72chevytrucks.com/vboard/s...4&postcount=61
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 07-29-2014, 12:56 PM   #6
Woodnears
Is this gonna be an issue with my porterbuilt control arms and ece modular spindles?
Woodnears is offline   Reply With Quote
Old 07-29-2014, 03:26 PM   #7
lolife99
lolife99's Avatar
Are you using 15" wheels with more than a 3.5" BS?
You definitely have more clearance with Porterbuilt a-arms than you do stock a-arms.
I have had a set of 15x7 truck rally wheels (3.625" BS),... with a set of RideTech a-arms with no clearance issues.
Porterbuilt arms should clear as well.
Keith
Old 07-29-2014, 03:42 PM   #8
Woodnears
They are the stock 6 lug rally wheels I'm pretty sure 8" wide.
They hit the fenders when fully deflated so I ordered ece modular spindles thinking I could squeeze them under the fender. I hope I didn't order something for nothing.
Old 07-29-2014, 05:22 PM   #9
lolife99
lolife99's Avatar
CPP is the only company that sells the 2" drop modular spindles.
Keith
Old 07-29-2014, 05:24 PM   #10
Woodnears
Sorry I meant cpp, I really like the look of the stock wheels
