Old 08-11-2010, 11:13 AM   #1
marcsRX
68 C10 SWB
marcsRX's Avatar
Lots of work to do.
Ordered sooo much crap.
Cant wait till it all gets here!!!
ECE Order
71-72 C-10 2.5 DROP SPINDLES
63-72 1.5" DROP FRONT COIL SPRINGS (SB)
63-72 6" DROP REAR COIL SPRINGS
KYB GR-2 FRONT DROP SHOCK
KYB GR-2 REAR DROP SHOCK
63-72 SHOCK MOUNT RELOCATOR KIT
65-72 SUPER TRACK BAR KIT
71-72 C-10 4/6 DROP KIT
63-72 POLYGRAPHITE SWAY BAR BUSHING SET
(1 1/16")
63-70 UPPER BALL JOINT
63-70 LOWER BALL JOINT
63-72 UPPER A-ARM SHAFT
63-72 LOWER A-ARM SHAFT
65-70 INNER TIE ROD END
65-70 OUTER TIE ROD END
65-70 TIE ROD ADJ. SLEEVE
68-72 PITTMAN ARM- POWER STEERING
67-82 IDLER ARM
68 C-10 FRONT END REBUILD KIT
(FOR USE w/ 800 SERIES P. STEERING)
71-72 R/H BRAKE CALIPER W/ PADS
71-72 L/H BRAKE CALIPER W/ PADS
71-72 C-10 5 LUG 12" FRONT BRAKE ROTOR
(CROSS-DRILLED LEFT SIDE)
(CROSS-DRILLED RIGHT SIDE)
71-72 DISC BRAKE PROPORTIONING VALVE
63-72 POWER MASTER CYLINDER
63-72 POWER BRAKE BOOSTER ASSEMBLY
71-72 BRAIDED STAINLES HOSE KIT
63-70 INNER WHEEL BEARING
63-70 OUTER WHEEL BEARING
63-70 INNER GREASE SEAL
WHEEL BEARING KIT
71-72 INNER/OUTER WHEEL BRG SET W/SEALS
68-72 POWER STEERING GEARBOX (2WD)
Jegs Order
Painless Performance Products #764-80300
Universal 3-Prong Sealed Beam Headlight Plugs, 2/pkg.
Painless Performance Products #764-10206
67-72 GMC/Chevy Pickup 2/4WD Custom Wiring Harness
Just for the hell of it, here are the pictures all of you have probably seen a 1/2million times.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
