Old 08-14-2014, 05:35 PM   #1
jstrong394
jstrong394's Avatar
Trans options for carb'd 5.3
Finally getting close to my ls swap. Hopefully. I'm looking to put the lm7 carb'd in my 2wd 85 c-10. Planning to put a bigger cam nothing to extreme. Was planning to do a th400 but just curious what else would be considered better. Would like to keep it simple. I know I have to buy engine adaptor plates to fit the engine but will the trAns all still line up with the drive shaft and everything?
jstrong394 is offline   Reply With Quote
Old 08-16-2014, 04:32 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Trans options for carb'd 5.3
It is not a hotrod, if it does not have the 3rd peddle! I run a stock (carbed) 5.3, 6spd Richmond box? 3.40 cogs in the back, 3.28 1st gear....2nd to 5th, close to a 2.20 Muncie.....76 on the OD ratio. cruise in OD, is 3100@105 mph, on a 29 " tire! You have to love the "screamin gears" under the old truck longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-16-2014, 05:51 PM   #3
jstrong394
jstrong394's Avatar
It's got 3 petals. Gas,brake, ebrake. Any tips on the 5.3 install? What other parts do you think I need off the top of your head. Engine, engine mount plates,intake, msd box. Was just going to figure it out as I go, but any tips would be excellent
Old 08-16-2014, 07:20 PM   #4
tinydb84
tinydb84's Avatar
Go to the price list thread for a bunch of part numbers.
The 400 is fine. I'd like another gear but if your rear gears are 3.08 or so you will be okay on the freeway.
David
Instagram: myfabguy
Old 08-16-2014, 08:49 PM   #5
crazy longhorn
The 400 trans will bolt right up the 5.3, but be missing 1 bolt hole (no biggy). I will leave flexplate selection/ adaptors to the guys running auto trans? as far as mounts on your square body, most of the guys like the dirty dingo sliders? Check the head to firewall clearance, on the rh side, as the engine sets farther to the rear in the 73-up, vs the 67-72's. If you have the clearance that you need, leave the trans & driveline in the same spot....too tight, hammer the firewall for clearance, or opt to move the engine & ahead /mod the driveshaft for the clearance.... (your choice)? On my truck, I used the edelbrock rpm (ls intake & controller). It is an MSD box, but with Edelbrock badging. A 670 avenger (Holley), should be a good addition for the street. I opted for Hooker streetrod shorties, to clear my mechanical clutch linkage, but you should have many other options with the auto trans(long or short tubes)? There again, I will let the rest of the bunch post up what fits your truck? Best of fun, longhorn
Old 08-16-2014, 11:17 PM   #6
ivorton74
ivorton74's Avatar
how about a nice 4l80e? I understand that they are basically th400 with an overdrive and way stronger than a 4l60
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 08-16-2014, 11:54 PM   #7
crazy longhorn
On a carbed LS, the the 4l80-E, will still need a computer control....unless you opt for full manual shift? longhorn
Old 08-17-2014, 12:08 AM   #8
Xeen
Xeen's Avatar
If you don't plan on driving it on the highway ever I would go with the TH400 but if you plan on some highway miles go with a 700R4.
The TH400 is much more stout than a 700R4 but unless you have over 400 HP you don't have to worry about it.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 08-17-2014, 07:32 PM   #9
jstrong394
jstrong394's Avatar
Thanks for the replies. The only real highway driving will be maybe 75 miles one way for crusin the coast.
Old 08-19-2014, 01:07 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I'd put in an overdrive trans in if you can work it....unless your rear end has tall gears. That's one of the main reasons later model engines get the fuel economy they do...because at cruise the engines run just a little above fast idle speed.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-19-2014, 10:56 PM   #11
dec010974
dec010974's Avatar
Hello to all. Jstrong394, gmcGMCCustom is rite, is you can wing it, go with an overdrive. My setup is a carbed LQ4/Th400 with a 2400 stall (cam asks for it). In comparison to my other cars I want the overdrive. The th400 is tried and true. I have a free 4l60e I want use but I need a ecu to controll it. Good luck Clark.
dec010974 is offline   Reply With Quote
Old 08-20-2014, 05:03 AM   #12
jstrong394
jstrong394's Avatar
Can any one post a link to the price list thread. I guess in over looking it
Old 08-20-2014, 03:19 PM   #13
tinydb84
tinydb84's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=473560
David
Instagram: myfabguy
Old 08-20-2014, 08:41 PM   #14
jstrong394
jstrong394's Avatar
Old 08-24-2014, 10:15 AM   #15
Pillow
Pillow's Avatar
This should help as well:
http://www.carcraft.com/techarticles...on_swap_gen_3/
Carbed LS w TH400 Muscle Truck porn:
https://www.youtube.com/watch?v=yGjMIjNkwhc
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 08-24-2014, 10:07 PM   #16
jstrong394
jstrong394's Avatar
That was a pretty good read. Talked with my father in law and he has 4 th400's I can pick from free of charge. The one with 30k miles has the e brake assembly on it but, he says he has an extra short tail shaft for it. So guess that is what I'm gonna go with
