Old 08-25-2014, 09:18 AM   #1
PGSigns
PGSigns's Avatar
What seat foam?
I need to rebuild my seat in the 66 and was wondering what density foam to use. The seat was recovered at one time and the cover is good but the burlap is falling apart and the cotton padding is falling out now on a daily basis. I was thinking 2 inch medium density for the bottom and 1" for the back. Does that sound about right?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-25-2014, 10:06 AM   #2
pimpston65
pimpston65's Avatar
Re: What seat foam?
Jimmy
this may not help, but i bought new burlap and used jute. the correct cotton can be had, but its pricy. or i would use 2" for added cushion...
pimpston65 is offline   Reply With Quote
Old 08-25-2014, 10:43 AM   #3
1963c-10
1963c-10's Avatar
Re: What seat foam?
When I had my custom cover done for the 63, we used 5" on the seat and 2.5" on the seat back. This was on a standard seat frame.
The factory was 6" on the deluxe seat, not sure about standard, but if I remember correct, it was only maybe 2 or 2.5".
The 65 deluxe seat I have is on the correct frame and has 6" foam.
1964 Short bed trailer
Old 08-25-2014, 10:55 AM   #4
Bears63
...just another truck junkie..
Bears63's Avatar
Re: What seat foam?
Check around with upholstery shops. You may be able to have them do it for less than you will pay for the foam. The foam is the expensive part. I did the seat for my C20 several years ago. I used 2" medium density on the back and for the bottom I used 3" of high density topped by 2" of medium density. Just the foam itself cost right at $300. Doing it again, I would just take it to an upholstery shop, even though that seat did end up like a big comfy couch.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-25-2014, 11:09 AM   #5
1963c-10
1963c-10's Avatar
Re: What seat foam?
I agree. I supplied material minus foam (seat, vinyl and cloth) and he charged $350 for labor, foam and rest of materials.
Old 08-25-2014, 12:55 PM   #6
PGSigns
PGSigns's Avatar
Re: What seat foam?
Foam is available on line for less than $80 for 2 sheets of 2" 24X72 and 2 sheets of 1" 24X72 all medium density. Found it on Amazon. Its a standard frame so it looks like 2" is it. I have done several covers so I have the hog rings and pliers and an old electric knife for cutting foam.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 08-25-2014, 02:33 PM   #7
LVPhotos
LVPhotos's Avatar
Re: What seat foam?
Since I was cutting and pasting, here is a seat from Mator.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
