Old 06-17-2014, 08:21 PM   #1
pocketpool
1969 project shortie
Thought i would share some pics of my latest project. 1969 cst I picked up. Bought the truck from the original owners son , so I am the 3rd owner. Bought it less than a block from my house. Patina is just awesome and will remain untouched. But I have since chopped it down to a shortbed.
pocketpool is offline   Reply With Quote
Old 06-17-2014, 08:39 PM   #2
pocketpool
Re: 1969 project shortie
Day I got it
Old 06-17-2014, 08:43 PM   #3
pocketpool
I can only post one pic at a time from my phone
Old 06-17-2014, 08:45 PM   #4
pocketpool
Frame cut
Old 06-17-2014, 08:48 PM   #5
pocketpool
Back together with early classic frame braces, had a short driveshaft from another truck, brake line had a compression fitting , shortened it. Cut some off fuel line and did a quickie exhaust swap and she was rolling again .
Old 06-17-2014, 08:51 PM   #6
pocketpool
12" out of the front of the bed , marked with tape and cut with sawzall. This was a wood floor bed , which was all rotted out , so it made it a lot easier .
Old 06-17-2014, 08:53 PM   #7
pocketpool
I put tape back to protect paint while welding and grinding. Wanted to keep as much of that awesome patina as I could.
Old 06-17-2014, 08:56 PM   #8
pocketpool
Start at the top when tacking up, if you go back between bottom and top it will not want to fit right, so start at top and work your way down , learned that the second time around
Old 06-17-2014, 08:58 PM   #9
pocketpool
8" out of the back
Old 06-17-2014, 08:59 PM   #10
pocketpool
Set that aside for now
Old 06-17-2014, 09:00 PM   #11
pocketpool
Bed back on
Old 06-17-2014, 09:02 PM   #12
pocketpool
Roll her out in the sun
Old 06-17-2014, 09:04 PM   #13
flashed
That is going to be nice ,Im in for the ride .
flashed is offline   Reply With Quote
Old 06-17-2014, 09:04 PM   #14
pocketpool
Slap the trim back on and admire your new old shortie
Old 06-17-2014, 09:05 PM   #15
pocketpool
Still need to finish up welding the sides up and cutting the trim to perfect length, needs new cab mounts and the body lines should be really close . Good enough for a old shop truck I chopped lol
Old 06-17-2014, 09:10 PM   #16
pocketpool
I have 8" steelies for the rear I'm painting back original color like I did the front. Gonna get 275/60/15 bfg's, fronts are 6" steelies with 245/60/15 with nova hubcaps . Plan is to slam 4.5/6" early classic and 5.3 with th350. Just gotta work some more overtime
Old 07-08-2014, 10:43 AM   #17
pocketpool
Decided to go with this chassis instead
Old 07-08-2014, 10:45 AM   #18
pocketpool
More
Old 07-08-2014, 10:46 AM   #19
pocketpool
Another
Old 02-22-2015, 11:24 PM   #20
pocketpool
Got a 5.3 for it, also decided to "z" the frame, wasn't low enough.
Old 02-22-2015, 11:25 PM   #21
pocketpool
Another
Old 02-23-2015, 11:44 PM   #22
pocketpool
Engine
Old 02-24-2015, 01:41 AM   #23
boynton
boynton's Avatar
Nice project!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-24-2015, 08:20 AM   #24
pocketpool
Thanks man
Old 03-13-2015, 11:02 AM   #25
pocketpool
Made some progress to the "z"
longbed to shortbed
