LS Motor Mount Conversion
What are you guys using for motor mount solutions and for relocating the transmission cross member? I came across this, but it seems pretty pricy: http://www.brphotrods.com/products/6...uck/index.html
Also what issues are you encountering with the oil pan? I've read that this LQ4 oil pan will be too large and hit the crossmember. |
![]() Join Date: Jan 2011
Re: LS Motor Mount Conversion
If you go tho the LS swap section all the info is there along with tons of build pics to show how all this works.
Jimmy http://67-72chevytrucks.com/vboard/f...play.php?f=206
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
![]() Join Date: Aug 2004
definitely do the hotrod oil pan( summit is your best option)
I used POL Perches but you could also use 73-87 clam shells, also look at the dirty dingo mounting plates, they allow a couple inches of movement to get things right where you want them. The guys are right, read through those posts and you will get lots of info!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
