Torsion bar adjustment 1961 C-20
I noticed the left side of my pickup is down slightly lower than the right.
Is there an adjustment to either raise the left or lower the right? |
Re: Torsion bar adjustment 1961 C-20
Passengers!
If it is a torsion bar set up you can adjust them by tighten or loosening them. Check to see if something is not causing it to lean. Mark your bolts before you adjust, so if you don't like it you can go back.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
