Old 10-02-2014, 06:40 AM   #1
marksp
1960-1962 vs 1963-1966 fleet side bed differences
What is different about the fleet side bed cross members from a 60-62 truck vs. a 63-66 truck? Most of the parts catalogs list them separately. I'm converting my 63 step side to fleet side and I'm not sure what year fleet side bed i have.
marksp is offline   Reply With Quote
Old 10-02-2014, 07:11 AM   #2
PGSigns
PGSigns's Avatar
Re: 1960-1962 vs 1963-1966 fleet side bed differences
The location of the cross supports are different for one. The 66 I have has the early bed strips in it from Mar-K and some of the holes dont line up. When I redid the wood it took a bit to figure that out.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-02-2014, 12:03 PM   #3
LVPhotos
LVPhotos's Avatar
The frames are wider on 60-62. So the frame holes would be wider, especially the rear most one with angle perches. Goto faq section lots of info and threads on this.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-03-2014, 08:25 AM   #4
Clyde65
Clyde65's Avatar
the 63-66 frames are the same. the 60-62 are the same. I believe the 60-62 are 42" wide and the 63-66 are 34" wide, I will double check that tonight.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-05-2014, 10:44 AM   #5
bmur66
Scored on a "brand new" 1986 GMC takeout bench for '65 GMC
No Weak Links
bmur66 is offline   Reply With Quote
