67 not so heavy chevy
Just bought a 67 c10 inline 6 292 with 3 on the tree. needs some love parts will be starting to roll in probably next month. I'll upload pictures when I get home at work currently.
Really new to restore or any motor work, that's why i'm here. I've got a small block 327 from a 67 chevelle. It's in pieces waiting to get block and heads cleaned, my questions for you gentlemen is the setup. I'd like to make this truck sound mean and produce a good amount of power. Right now the block is bored over 30 looking at boring over 40. So it's a matter of finding the right setup hoping you guys could lead me in that direction. Want to run rocker roller setup for valves and I want a mild cam to give it the classic muscle sound. I'm just a young buck willing to learn I tore the motor down myself and willing to put it back together for my not so heavy chevy. Thanks, Joe. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 67 not so heavy chevy
Welcome to the board from southern oregon... Got any pictures of the truck?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Aug 2012
At .30 over gives you a 383 cubic small block. Don't know what .40 will give. Be careful not to go over .40, then you might be heading for trouble if the wall are too thin. But this in my thought. I think you are working in the right direction. Are you going to tear it down all the way to the frame or is it going to drive and work on the truck. I took mine all the way to the frame. I am glad I did for I found out week spots in the frame and other spots also. anyway good luck and it don't hurt to post pictures for these guys and myself need visual references to help you.
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
#4 | |
Other than that not really going to clean the frame up doesn't need it too much. Thinking i'll try and find some DART heads to run seen few good reviews on them. Pictures when I wake up today I work 7pm to 7am so i'll post pics around 3-4ish |
More pics of the truck please! Welcome to the board!
A 400 crank and .030 bore will give you a 383. A .030 over 327 will give you like 333 or something With a 327 crank(not really sure) A 327 block is the same as a 350 but has a 307 style crank from what I'm told. So the pistons don't move as much up and down in the bore giving you less displacement. A 400 crank makes the pistons move a lot more up and down giving you a lot more displacement and torque. It's kinda like using a small ratchet on something and switching up to a breaker bar. Most 350 blocks can go .060 over but as mentioned above you would be pushing your luck. .040 would be ok but make sure you get the block sonic checked. This will determine the thickness left in your cylinder walls. I would use what I have on hand before switching up to Dart heads and such. You can spend a butt load of money quick not knowing what you should buy and end up with an expensive turd of an engine. 327's are tricky lil buggers so you need to know a bit about engines and intended uses of your truck. Are you gonna race it or use as a truck? You know = haul hay around a farm. A 327 will spin high rpms but not much torque for hauling in stock form.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I'd like to try and make it a street/strip truck if possible. The guy i bought it off of gave me the cab mounts and rocker panels for it.
Love ,Love ,Love 67's. Looks like a nice start. Schweet front clip! A little jealous here.
For poops and giggles bought some headers for the 292. Plan to run 292 for a year or two as i'm not in a hurry to build the 327. I love the truck its beautiful and an antique now
Need help on how the beds go together on this truck, have a huge manual at home that I've been looking through but not detailed as I like.
New plans, making a flat bed for my chevy and I'll run it for a couple of years. Going to be doing rocker panels and cab corners here in the next two weeks or so, kick is I will not be welding them.
I will be using a glue, specifically Lord Fusor 116. |
Got a little bit of work done today. Took the hood off, got the inner fender wall out on the passenger side. Took longer than i wanted, had to grind the hood off and grind bolts in the wheel well out someone caked a rust spot with putty which went over my bolts.
Now i have to get a passenger side door and need two new fenders for the front. Noticed some rust on passenger side door that is bubbling bad poked hole through it. ![]() ![]() ![]() |
Wow that is some rust. Gonna be some serious work ahead of you I fear.
