Old 10-29-2014, 12:11 PM   #1
low1954
1972 chevy k20 front brake hose info?
I'm am looking for answers!!! I am trying to find out
The thread size of the fittings on my front brake hoses. I have
Found out that the side that bolts to the caliper is a 7/20 banjo bolt? Is that correct? However I can't find what type and size of the fitting that is on the frame side. My truck is a 1972 chevy k20. I am wanting to know this info
So I can make my own braided lines. I have the braided line, but need to order
The correct fittings. Any and all help would be awesome. Thanks Jeremy
low1954 is offline   Reply With Quote
Old 10-29-2014, 04:10 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 1972 chevy k20 front brake hose info?
My only suggestion (not much help, I know) is buy or borrow one from a parts store. I bought new ones at NAPA recently, perfect fit and not too expensive IIRC. At least you'll be able to see exactly what size/type fitting is used, as well as the threads.
Edit: checked online, found p/n UP 36761 with pics and a description including thread size.
http://www.napaonline.com/Catalog/Ca...761_0342274941
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-30-2014, 08:33 AM   #3
low1954
Stocker I tried to find some info on that part number
You sent, no luck. Thanks for the help though.
Old 10-30-2014, 10:37 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's a NAPA part number -- did you check with a NAPA store? Were you able to click on the link I posted? Here's what the link has about the threads on each end of the hose:
Hose End Type 1 : Banjo - 0.44
Hose End Type 2 : Male/female - 5/8"-18 Ext & 3/8"-24 Int
- Mike -
RIP El Jay
Old 11-01-2014, 04:29 AM   #5
swamp rat
swamp rat's Avatar
I don't recall the thread size on the frame end of my 72 K20 but i bought new hoses from Offroad Designs for my truck after i installed my 4" lift. This is the part number they sent me, if your still searching maybe a call to them would help id the thread size?
(GU30071) BRAKE LINES - VEHICLE KIT (‘73-‘78.5 -- 4-6” lift) (2 fronts, 1 rear)
http://offroaddesign.com/catalog/braidedbrakelines.htm
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
