Old 11-15-2014, 03:05 AM   #1
Gregski
Gregski's Avatar
Sticky Gooey Steering Wheel
Fellas
My steering wheel looks and feels like someone dipped it in tar, WTH?
I took it off and am soaking it in a big plastic tub full of hot water and dish soap.
Has this happened to anyone else, I am in Northern California and bought the '74 bugger off an old farmer, what in the world did he do to it, LOL?
Gregski is offline   Reply With Quote
Old 11-15-2014, 05:06 AM   #2
tucsonjwt
Re: Sticky Gooey Steering Wheel
Very common. Dirt and sweaty hands create gunk. Use orange hand cleaner and rub it in, then use soap and water. Cover with two or more steering wheel wraps which are the lace up kind, but have a foam backing. Use the normal size for the first wrap, get an oversize one for the second wrap. Converts the old skinny steering wheel to a more modern fat steering wheel. In the future, you can discard the outer wrap and install a new one if you don't want to clean it as described above. About $8 for a wrap.
tucsonjwt is offline   Reply With Quote
Old 11-15-2014, 02:18 PM   #3
mattybilt79
I have had multiple trucks with that problem. Seems to be worse the longer that the vehicle has sat. Honestly I think a lot of it is the resin sweating out of the wheel. Always have used cleaner of choice and scrubbed it off and issue usually goes away after driving regularly.
mattybilt79 is offline   Reply With Quote
Old 11-15-2014, 05:27 PM   #4
Gregski
Gregski's Avatar
Originally Posted by mattybilt79 View Post
Honestly I think a lot of it is the resin sweating out of the wheel...
You know Matt that's what I thought too, glad someone else shares that idea, cause there's no way it could be grease seeping upwards (defying gravity) out of the steering column
nasty stuff, don't wish it upon anybody
Old 11-15-2014, 05:25 PM   #5
Gregski
Gregski's Avatar
Originally Posted by tucsonjwt View Post
Dirt and sweaty hands create gunk. Use orange hand cleaner ...
Man mine can't be dirt and sweat, cause I can remove dirt and sweat with a paper towel and a garden hose, my stuff is like whale snot, LOL I am scraping it off with a screw driver and it comes off like rubber cement
went out and bought the orange cleaner, and this gunk just laughed at it, it totally did not work at all and I scrubbed the sh!t out of it
only thing semi working is Acetone (the stuff you use before you go and paint something)
Old 11-15-2014, 06:08 PM   #6
franken
I soaked a wheel in purple power for a few days and that cured it...
Old 11-15-2014, 06:59 PM   #7
slam59
Hey gregski that's the same problem I'm having and it is nasty sticky stuff. Gonna try the purple power
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 11-15-2014, 11:25 PM   #8
farmall
farmall's Avatar
Its the rubber/plastic breaking down. Throw it away.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 11-15-2014, 11:43 PM   #9
franken
No, old hard plastic shiny wheels may not be savable, but more newer ones are.
The plastic is different.
The one I fixed was from a scrapyard car and nasty. Cleaned up like new.
I also have a black shiny plastic wheel that isn't sticky, so who knows.
Old 11-15-2014, 11:48 PM   #10
bnoon
Yeah just grab one out of the salvage yard that isnt breaking down.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-16-2014, 06:33 AM   #11
tucsonjwt
So just cover it up with wraps?
Old 11-16-2014, 08:36 AM   #12
donut
donut's Avatar
I've used acetone, wd-40, lacquer thinner... whatever works. It will take elbow grease and some work. If you get it where the rag comes out clean, then your good. After that you can keep it clean with the cleaner of choice and or wrap it if it's bad.
Grabbing one out of the junk yard, IMO, is a crapshoot. You may have the same problem, just one you already have money into.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-16-2014, 10:08 AM   #13
Dead Parrot
Mine was doing that. After many attempts with various cleaners and solvents, gave up and went to Pull-a-Part. A bit of wandering about the GM car section, found a 80's era Blazer wheel that after checking fit and look on a square in the yard, took home for $5. It is black and has a Chevy emblem on the horn button. Also took home a Pontiac wheel as a spare that didn't match the column as well, functionally fit fine. Also $5.
Dead Parrot is offline   Reply With Quote
