Old 11-16-2014, 03:17 AM   #1
ellisjay2
Changing thermostat housing on electric choke??
The rivets on my electric choke housing are missing and now will not stay in proper adjustment due to winter arriving. Ive found a website that sells quadrajet carb parts and will order thermostat housing kit and wire. Is it simple to replace with carb on or will carb have to be removed???? I have to get under the hood on cold starts to lift up choke plate, move it back and forth until mixture and temp equalize, then it will stay open on its own, Im not sure who removed the rivet screws, but they had a zip tie around the thermo cover to hold in place.....
http://quadrajetparts.com/images/GHP-Q1211-W600.gif
ellisjay2 is offline   Reply With Quote
Old 11-16-2014, 06:29 AM   #2
tucsonjwt
Re: Changing thermostat housing on electric choke??
I would replace with manual choke.
tucsonjwt is offline   Reply With Quote
Old 11-16-2014, 08:54 AM   #3
Mv7fd
perfect time to upgrade your carb!
Mv7fd is offline   Reply With Quote
Old 11-16-2014, 09:45 AM   #4
Axle
Axle's Avatar
[double post]
Axle is offline   Reply With Quote
Old 11-16-2014, 09:59 AM   #5
Axle
Axle's Avatar
ellisjay2, the thermostat can be r&r'd with the carb on the vehicle. The replacement stat comes with self tapping screws and the little wing washers (at least whatever I got from Napa years ago did).
Alex.
Old 11-16-2014, 12:03 PM   #6
cadillac_al
I would just put some screws in it to replace the rivets and use the one you have.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-16-2014, 12:07 PM   #7
gmachinz
That is the best route imo . That way, you can easily adjust the choke setting for winter or summer driving.
gmachinz is offline   Reply With Quote
