Old 11-29-2014, 04:46 PM   #1
jetmech85
Where is '86 Neutral Safety Switch?
I suspect my neutral safety switch could be faulty, but I can't locate it. I have an '86 Suburban with 350 and 700R-4. I already bought a replacement and it looks like my backup light switch except it has more metal terminals on it. My original switch only has two metal terminals for the backup lights only. I always thought the neutral safety switch and backups were part of the same assy. I looked on three other '86 parts trucks and were all like mine, backups only.
jetmech85 is offline   Reply With Quote
Old 11-29-2014, 04:56 PM   #2
craig113
Re: Where is '86 Neutral Safety Switch?
inside cab, base of steering column at the fire wall
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles
91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles
96 K15 Sub 350/4L60/243c/10 bolt 333k miles
craig113 is offline   Reply With Quote
Old 11-30-2014, 12:56 AM   #3
jetmech85
OK, I am reading on another forum that an '86 does not have a neutral safety switch. I have the original backup switch and no terminals for any other harness. Checked my driver and two parts trucks, no nss on any of them. Any other '86 owners ever run into this oddity?
Old 11-30-2014, 09:53 AM   #4
hatzie
Moderator
hatzie's Avatar
1986 Automatic transmission GMC & Chevy CK 10-30 Neutral Safety & Backup Lamp switch
ACDelco D2286A, Standard Motor Products NS41
The wiring diagrams only show backup lamps attached to that switch.
There may be a mechanical lockout. Can the key be turned from the run to the start position if the column isn't in park?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-30-2014, 11:10 AM   #5
jetmech85
Thumbs down Re: Where is '86 Neutral Safety Switch?
Yes that is the replacement switch I bought however my original switch does not have the metal terminal blades for the NSS. I understand they make a single part to fit more than one application. It seems that from what I am finding out that beginning in '86 they started using a mechanical lock-out that won't allow the key to rotate to the start position unless in park or neutral. That feature continued on to later years. Although in '87 and later the switches had a plug attached to the NSS postion, it was for computer information only and not a part of the starter circuit. So, after all that my problem was my three month old Powermaster starter took a dump. I tend to over look the new parts being faulty when troubleshooting.
Old 11-30-2014, 11:14 AM   #6
jetmech85
Sorry, Sean, you posted while I was typing. Absolutely correct. Mechanical lockout.
Old 11-30-2014, 02:25 PM   #7
hatzie
Moderator
hatzie's Avatar
Try '85 and later. '85 shows the same switch in the wiring diagrams as '86.
'85 & '86 have several unusual features.
'84 and prior have the neutral safety switch in the diagrams.
That's why I asked. My 85 was a floor shift 4 speed so none of this applied to it.
Old 11-30-2014, 11:02 AM   #8
Just call me Sean
Just call me Sean's Avatar
Yep, there's a mechanical lockout that prevents the key from turning.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-30-2014, 11:09 AM   #9
kalbert
What are the symptoms you're having that is making you suspect a faulty neutral switch?
kalbert is offline   Reply With Quote
Old 11-30-2014, 03:48 PM   #10
jetmech85
My '85 is a floor shift also. It has a clutch petal position switch that someone has bypassed. I would like to restore it but they decided to throw away the connector. Its on my junk yard list.
Old 11-30-2014, 05:22 PM   #11
Just call me Sean
My '83 has the mechanical lockout also.
Old 11-30-2014, 05:59 PM   #12
hatzie
Moderator
hatzie's Avatar
It may be part of the whole design change from floor dimmer button and wiper switch on the dash to the column mounted multi-switch.
Old 11-30-2014, 06:12 PM   #13
Just call me Sean
I doubt it. I have a floor mounted dimmer and dash mounted wiper switch.
