Old 12-01-2014, 12:50 PM   #1
mlbrickey
Exhaust thoughts
My 70 has a major exhaust leak. It has the original ram horn manifold. The PO replaced the rest of the system with glass packs. It looks like there maybe a crack in the down pipe coming from the manifold. Should I replace the manifold or just the down pipe? Thoughts fellas?
mlbrickey is offline   Reply With Quote
Old 12-01-2014, 01:18 PM   #2
truckster
truckster's Avatar
Re: Exhaust thoughts
If the manifold isn't cracked or warped, I see no reason to replace it.
truckster is offline   Reply With Quote
Old 12-01-2014, 03:10 PM   #3
KEL
72 GMC
KEL's Avatar
I have stock manifolds and glass packs
quiet in the cab and outside sounds good goiing down the road
why mess with a good thing ?
good luck and spend the money someplace else.
KEL
Members I have met :
2014.02.01: bruceman1968, Mr Handy, colgad, RenoKeene, CaptRMW
KEL is offline   Reply With Quote
Old 12-01-2014, 03:11 PM   #4
KEL
72 GMC
KEL's Avatar
by the way
WELCOME !
KEL
Old 12-01-2014, 04:23 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, just replace the cracked downpipe.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-01-2014, 06:47 PM   #6
R.L.
R.L.'s Avatar
Welcome to the forums, just replace the down pipe.
R.L. is offline   Reply With Quote
Old 12-01-2014, 07:59 PM   #7
tcrist
Can you see a crack in the down pipe or is that where the sound is coming from?
The down pipe probably has a doughnut gasket on it and it could be loose, blown or completely missing. Have you tried just tightening the pipe at the manifold?
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 12-02-2014, 12:53 PM   #8
mlbrickey
Thanks fellas, I will investigate further.
Old 12-02-2014, 04:44 PM   #9
67 chevelle
67 chevelle's Avatar
Ram horn manifolds are generally regaurded as high quality , high performance manifolds , work well and are worth keeping
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
