how to get clips in holes on stainless door moldings on 56 gmc
I ordered new clips for my stainless and cant get them to go in the holes. anyone know of any tricks on how to get the new clips back in? I am using the orginal moldings as they are in perfect shape
Re: how to get clips in holes on stainless door moldings on 56 gmc
I recently had a thread on this a couple months ago. After much consternation, I ended up tweaking each clip slightly with a couple pair of needle nose pliers to reduce the angle of the tip of the clip. I also snipped off about an 1/8" off the tips. There are holes around the top of the door where the clips bottom out if they are not trimmed. DON'T tweak the tip angle too much as it takes some tension to hold the molding against the cab. Bend the angle a tiny bit and try pushing in the hole until it feels right.
"Built- not bought" 1958 GMC 150 4x4 in progress 1980 K20- Restored 1985 K3500 Flatbed 58 GMC 4x4 build thread: http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675 |
thanks I will try that
