Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-14-2014, 12:20 PM   #1
creamed12
2008 GMC Yukon headlight wiring
I am currently working on a 1977 C10, I plan to install the dashboard from a 2008 Yukon. Also I am going with the speedometer, engine and transmission from the 08 Yukon, so I will have the BCM and ECU. I do have a wiring schematic for the 08 but could someone PLEASE simplify this? I need to know how to wire the headlight switch, brake lights and turn signals into the 77 C10.
THANKS in advance for any help.
creamed12 is offline   Reply With Quote
Old 01-10-2015, 03:06 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 2008 GMC Yukon headlight wiring
Aren't those controlled by the BCM?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-11-2015, 11:20 AM   #3
creamed12
Yes they are. I have the BCM, I intend to install it because of the instrument cluster. I was hoping someone could help me simplify the wiring.
