Old 01-06-2015, 11:26 AM   #1
locoluis30
Saginaw power steering pump
I have an 86 truck with the stock gearbox and steering pump , still there as I am upgrading everything with billet pulleys. I have the billet pulley for the pump already, but is bolt on , so I got me a 70 camaro remanufactured pump (bolt on) with the billet bracket as we'll. easy swap.I hate the press on pulley type. My problem is that my 86 stock pump has O rings and I believe metric fitting .How can I replace the lines to fit from my gearbox to the 70 camaro pump? Thanks!
locoluis30 is offline   Reply With Quote
Old 01-06-2015, 02:19 PM   #2
65 C20
Re: Saginaw power steering pump
I believe that you can purchase an adapter that screws into your pump.
Try your local parts store first.
I have never bought one so maybe someone who has will chime in.
65 C20 is offline   Reply With Quote
Old 01-06-2015, 02:39 PM   #3
ray_mcavoy
You can simply unscrew the outlet fitting from your 86 pump and transfer it over to the 70 pump. Then you'll be able to use stock 86 O-ring hoses.
Just be careful when you unscrew the fitting ... there is a pressure control valve and spring in there.
ray_mcavoy is offline   Reply With Quote
