Old 01-02-2015, 03:40 PM   #1
bikejunkie1013
Can this be fixed?!
I just picked up a 72, C-10 with air ride.
But the right side bag was not working.
Jacked it up and found this!!
Anyone have a spring mounting plate??
bikejunkie1013 is offline   Reply With Quote
Old 01-02-2015, 03:44 PM   #2
67 cst swb
67 cst swb's Avatar
Re: Can this be fixed?!
Oh My God... and I thought my truck was rusty.
I think you will be looking for more than a mounting plate.
Look at that trailing arm...?
...and welcome to the board!
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-02-2015, 03:55 PM   #3
bikejunkie1013
The other trailing arm looks worse.
The frame will need a little welding, guess I need a spring mount plate?
Old 01-02-2015, 04:01 PM   #4
stomper
Junior Member
stomper's Avatar
Omg!
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 01-02-2015, 04:05 PM   #5
Fitz
A spring mount is the least of your problems. The frame U channel has collapsed at the mount from the rust and there is another place where the frame is distorted and torn. It can all be fixed, but it is a matter of how much you spend. You WILL spend quite a bit because what you have now is not safe. That frame looks like it's toast and I can not see how those trailing arms are still in one piece. Shock mounts aren't correct for a coil rear, either. This looks like someone hacked a 67-68 suspension under a leaf spring truck. I would look for a different frame as the VIN goes with the Cab, not the frame.
No Limit has a back-half kit (raised rail) if you were planning on dropping the truck which essentially replaces the frame from the trailing arm crossmember back but cost is about $1100.00 and it will take a lot of skill to get it right. An alternative is to shop for a new frame from the local junkyards. Here in AZ they are available for about $750-1000 but you have to pick it up.
Fitz is offline   Reply With Quote
Old 01-02-2015, 06:38 PM   #6
65standard
65standard's Avatar
Is the frame rail supposed to be push up against the wood floor?
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 01-02-2015, 07:18 PM   #7
davepl
davepl's Avatar
If it were me I think this would be a parts truck or would require a parts truck. Trucks of this era were slightly overbuilt, but they had slide rules. There's not an abundance of extra structural steel back there, and most of what you have appears corroded.
Just because something doesn't have a hole in it doesn't mean it's not weakened.
Sorry to be the bearer of bad news, but I think you've got some serious safety concerns there. Others might have faced rust like that (I'm from the Midwest and that's a lot to me) and be less pessimistic or have tips on how to proceed.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-02-2015, 07:29 PM   #8
65standard
65standard's Avatar
What the rest of the truck looks like would determine if it is worth fixing.
Old 01-02-2015, 07:51 PM   #9
R.L.
R.L.'s Avatar
X2.....I hate salt.
R.L. is offline   Reply With Quote
Old 01-02-2015, 08:04 PM   #10
caddyhack
caddyhack's Avatar
It all comes down to how much time, money and mechanical ability you have. If the rear looks like that i bet the front end isnt much better at all. It might be better to get a new frame or make your new truck a parts truck. Is the body, interior and motor good? If they are nice i would swap the frame if they need work too i would use it for parts.
I wish I was rich instead of so damn good lookin!!
caddyhack is offline   Reply With Quote
Old 01-02-2015, 08:22 PM   #11
Jim53066
Jim53066's Avatar
Can this be fixed?!
YES, anything can be fixed if you throw enough time and MONEY at it.
I think it would be wiser to take the good parts off and put them on something solid. Since yo are from MO. I am sure you can find something much, much better at a reasonable price.
Jim
Jim53066 is offline   Reply With Quote
Old 01-02-2015, 08:47 PM   #12
dubds10
Stalker Nate
Looks like a parts truck. I hope the body is more solid than the frame or you got the truck for $400 as then you can take the good parts & scrap the rest. Deff need to see a full photo but that entire backhalf is gone & not safe or road worthy.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 01-02-2015, 09:21 PM   #13
The front half of frames seem to hold up pretty good. The rear gets it all thrown back at it and air flow, oil leaks, and flung grease do wonders for a frame's complexion. Sorry about your luck, this one's roached. Is it a shortbed or longbed, can't quite tell. I can't believe someone put bags on a frame like that. Just go on with it, I guess
Old 01-02-2015, 09:31 PM   #14
Elliot949
Elliot949's Avatar
I think your easiest and cheapest way to fix this is a different frame...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 01-02-2015, 09:53 PM   #15
bikejunkie1013
It is a 72 blue long bed withwood floor
Air bags front and rear.
The cab was fixed 10 yrs ago so it's starting to get some bad spots, but pretty solid.
383 stroker and the stock saginaw 3 speed.
May be parting it out, THE MOTOR IS MINE!!
Pic's soon. its dark now.
Old 01-02-2015, 11:22 PM   #16
WIDESIDE72
WIDESIDE72's Avatar
WOW. Air ags on a junk frame. Also...saginaw 3 speed was never intended to stand up behind a 383...what were they thinking???
WIDESIDE72 is offline   Reply With Quote
Old 01-03-2015, 10:42 AM   #17
cooperhw
cooperhw's Avatar
Holy Toledo, Columbus Ohio.
U need a new frame under that bad boy. Too bad you are soo far from AZ. About $300 here will buy you a straight rust free frame. Heck a guy I know has a roller complete with a 6 cyl. motor for $350.
Rust YUK.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 01-03-2015, 07:26 PM   #18
no1udknow
no1udknow's Avatar
holy crap... that's sketchy, new frame all the way. If that's the back half of the frame, who knows what else is compromised... and the air ride is only going to make it worse. if the body is clean... then you need a frame donor for sure.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 01-04-2015, 12:58 AM   #19
70CHEVYBB
70CHEVYBB's Avatar
yes you can fix that
70CHEVYBB is offline   Reply With Quote
Old 01-05-2015, 12:57 PM   #20
bikejunkie1013
Here is the rest of the truck.
It has a brand new re-pop tailgate still in primer, 5/4" decking wood bed
Someone posted it was a $400 truck, Really?
Old 01-05-2015, 01:11 PM   #21
Ft.ValloniaStreaker
Ft.ValloniaStreaker's Avatar
Yes it can be fixed...hell anything can be fixed! If your in $400 then your at least $19,600 better off than a lot of guys on here. Take your time find good people locally to help you out and enjoy that ole thing.....
Ft.ValloniaStreaker is offline   Reply With Quote
Old 01-05-2015, 01:15 PM   #22
bikejunkie1013
I didn't pay $400.....I paid less.
It will be a nice cruiser, got a frame guy (does back halves and stock cars)
He will fix me up. And it will be faster with a lighter wallet.
I need trailing arms and a stock seat...
Old 01-05-2015, 03:31 PM   #23
67 chevelle
67 chevelle's Avatar
Post pictures along the way , when repairing , we love that stuff . Your truck looks great ,,,,,,from above,,,,, even putting on a lift would scare me , but if the front half of the frame is solid """which I doubt'''''' you could weld in the back half from a doner ,,,, new frame would be better ,,, there are tons of them around but lots of rust in your area
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-05-2015, 04:42 PM   #24
RenoKeene
Florida Edition
RenoKeene's Avatar
Yep, I'd get a different frame. If you lived around here (or come down on vacation) I have a perfectly good LWB frame I'd let you have for free.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-05-2015, 05:12 PM   #25
67ChevyRedneck
67ChevyRedneck's Avatar
Holy crap, I've seen NY trucks with better frames.
I'd have a hard time believing the front doesn't look just as bad?
Check inside all of the areas where all the cross members connect to the fame, they're notorious for rotting out there too... and if the back half is that bad...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
