Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 01-10-2015, 09:47 PM   #1
VetteVet
Msgt USAF Ret
VetteVet's Avatar
How our starters work
This may help a lot of you understand how the starter works and be able to trouble shoot them.
The starter cycle starts with the key switch turned to the ST position and power is routed via a 12 gauge purple wire to the neutral safety switch on automatics, and to a neutral or safety switch on the transmission, and some times on the later models, to a clutch switch. From there it goes through the firewall block to the S terminal on the starter solenoid.
The solenoid is an electromagnetic device that also acts a relay. The electromagnetic function pulls the starter bendix lever and throws out the starter gear to engage the flywheel.
At the same time the contact washer in the solenoid inside near the rear, moves to the rear and joins the two main terminals on the starter. The battery cable at the top and the starter field terminal at the bottom.
Note the red arrows.
This feeds battery power to the starter windings through the starter brushes and spins the starter armature turning the starter gear and the flywheel.
When the key is released the key switch goes to the ignition position and
releases power to the solenoid and a spring inside the solenoid returns it to the forward position breaking the contact on the two main terminals for the starter and the cycle stops.
shown below.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline
