My Late, Very Slow 84' C10 Build.
I've been lurking around for a LONG time, couldn't begin to explain how much I've learned on this forum about these trucks.
I'm 17, what I know is mainly self taught/trial and error. I work as an AG "Tech" at a New Holland/Kuhn/Kubota dealer and spend most of my time around hay and corn harvesting equipment. This truck is one of a few toys I have and it's been pushed to the side while I work on the others (67' F350, daily driver F150, dirtbike, tractors...), I just recently started back up on it and goal is to have it road worthy and presentable by late March 2015. Work part time for the most part so funds are a little low right now, but my spare change is dedicated to this build now. The truck started life as an 84' SWB C10 Custom Deluxe, 6 banger Auto, I bought the truck cheap as a running/driving bucket of rusty bolts with a pre-vortec centerbolt headed 350 and heavily built (possibly TCI crate) TH350 installed in it. A few years ago I stripped it down to bare frame and it sat around until late June 2014. I bought a rust free 84' nose, 87' Silverado cab, and 86' Fleetside bed as the body wasn't solid enough to justify repairing. The motor that is in it now is an old 377 out of a Super Modified (destroked 400) that has been rebuilt with streetable compression, a milder cam, and a laundry list of other components. My goal for the truck is to build it respectably clean, keep it simple, and maintain all the practical aspects of a truck. It WILL be used as a truck, it WILL go through multiple pairs of rear tires every few months, and it WILL be driven, hard. ADHD is kicking in so, pictures: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And an interesting idea the PO had: ![]() Last edited by 83swb; 01-15-2015 at 10:00 PM. |
Re: My Late, Very Slow 84' C10 Build.
I bought some mufflers for the truck a few days ago, a pair of stainless 4"x14" Jones round case mufflers (identical to a magnaflow #10416), and welded some 2.5" pipe to the pair of reducers that Hedman included with the headers. It sounds incredible, but with the truck toned down from open headers I could hear that the power steering pump was whining and making more than a few noises it shouldn't. With the truck running there were also a few tight spots before reaching full lock, hoping that it's related to pump pressure and not blockage in the steering box.
I ordered a new pump to fit an 84' C10, but I'm unsure if the pump and the mounting brackets are original to this generation truck. I would really appreciate it if someone could shed some light on it. Here's the pump fully dressed: ![]() ![]() The stud and mounting bracket (Sorry for the poor quality picture, new camera): ![]() |
I also had an issue with the new rear drums I bought for the truck, turns out that they no longer put a cutout in drums for shoe adjustment, Why? who knows. Nobody offers drums for theses trucks WITH an access hole.
I did find a solution to the issue. I drilled a 19/32" hole in the backing plate behind the shoe adjustment linkage, it's plenty enough to get a decent size screwdriver through. This camera really shows the flaws in my finish and paintwork, now I have to get under there and clean it up. ![]() ![]() |
![]() Join Date: Mar 2013
Nice work. It's great to see a 17 year old interested in mechanical things. Look forward to more updates.
driving is in my blood
Ahhh, nothing better then a good DE-stroking of an engine. I'm jealous. Truck looks like its moving along nicely.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Thanks for the comments, I appreciate it. Trying my best to keep momentum on it, working on it in an operating shop so my time to work in it is limited.
![]() Join Date: Oct 2013
I will try to post photos and check my 86' PS pump, to compare to yours. Mine is origional to my truck. You may be able to see a little on engine photos on 86'.
More later, Les |
A couple of PS photos before R/R on 1986' C10, 2 wheel drive, and non-air.
The 86, may not be correct for you? The 86 is the same as 87, but not sure for 84? At least you can see where it mounts to engine, that may be the same. See if your belt lines up with pulley. Les Last edited by aotte1; 01-24-2015 at 01:51 AM. |
Another
A few more
Last origional PS photo
Nice work!
1983 GMC SWB - 350, TH-400 2002 Camaro SS - 408 9sec street car 2000 Trans Am - H/C/I 2014 Chevy Z71 |
#15 |
A few more photos, of PS unit cleaned up.
#16 |
