Old 01-30-2015, 01:59 PM   #1
no1udknow
no1udknow's Avatar
LS swap..maybe
Hey guys,I'm still trying to decide on an ls swap. I've finally locked down a decent price on an ls swap. Local junker has 5.3's with the harness and brain for around $750. Then I need to find a trans and I am deciding still between a manual and a 4l80e. I would need to sell my current setup, I don't know if this is safe to ask or if I get flagged, but I have a built 350 (364 actually) and a 350 tranny, I was going to list them on my local craigslist but I have no idea what an engine and trans package goes for these days. Other than the engine, trans, mounts, exhaust, and wiring, what things will I need to complete the swap?
I go back and forth. I like the old school, easy to work on engine with carburation, but at the same time, I like the driveability, reliability, power, and mileage of the FI system. Maybe I should just buy another c10 and pop an LS in it that way I have both
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 01-30-2015, 02:15 PM   #2
hugger6933
Re: LS swap..maybe
Not that this has anything to do with your post but why not include the possibility of a 4l60E? It just seems a better fit behind the 5.3 than the L80E. Just wondering
hugger6933 is offline   Reply With Quote
Old 01-30-2015, 09:53 PM   #3
Marty68
Re: LS swap..maybe
i just started my swap. i had a mild build 350/350 trans would have needed rebuild. i sold them seperated but as a package to a guy building a 40 ford rat. $800 bought 01 4.8 4l60 harned fuse block drive shaft 1k. working harness now. if you havent yet check out this thread.http://ls1tech.com/forums/conversion...71-c-10-a.html
he is a member here and does AWESOME work.
Marty68 is offline   Reply With Quote
Old 01-30-2015, 10:04 PM   #4
elimontfort
elimontfort's Avatar
Re: LS swap..maybe
I sold my 327/700r4 for 1100 bucks. It was a mild 327 and a junkyard 700r4. And I was like you I liked the 327 cause it just sounded nasty with that big ass cam and headers but it wasn't even close to the power that my lq4 has and it's basically stock parts 243 heads and a ls6 cam. The way the power comes in is awesome. The motor sounds very tame compared to the 327 but man you step on the gas and its a monster. I don't regret doing the swap.
elimontfort is offline   Reply With Quote
