Old 01-02-2015, 10:42 PM   #1
Gregski
Gregski's Avatar
No Way Is This The Source Of My Oil Leak?
this can't be where my oil is leaking from can it, that piece above the starter should be a solid chunk of metal, no? what are those two bolt holes for, application for a different car?
Gregski is offline   Reply With Quote
Old 01-02-2015, 11:24 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: No Way Is This The Source Of My Oil Leak?
No oil goes through there.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-02-2015, 11:46 PM   #3
86c20
86c20's Avatar
only way i see oil there is from back or intake or vavle cover down to the bell and then out the holes. only way i see. and that is a stretch
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-03-2015, 03:58 AM   #4
andrewmp6
See if the flexplate is coated in oil,If it is its your rear main seal.But like others have side its probably from up higher and dripping down.
Old 01-03-2015, 07:48 AM   #5
homemade87
From the looks of it thru your starter hole it looks pretty black and wet . If I was a guessing person I would say there is a rear main seal leak . If you had oil moving around on the back of the block it could get between the trans and engine block mating surfaces . It looks like its coming from the locating pin for the trans . That is a thru hole in the block with a pin in it . It could be possible for oil to make its way past that pin from the back of the block if oil gets trapped between the 2 mating surfaces . It looks to be a very minor seep . Not the source of a major oil leak . Oil is originating from some where else . What you are seeing is collateral damage .
homemade87 is offline   Reply With Quote
Old 01-03-2015, 10:47 AM   #6
hatzie
Moderator
hatzie's Avatar
That's coming from under the bellhousing. It's a little odd that the bellhousing and inspection cover look wet but the flex plate looks dry.
The oil pressure senders are on the other side of the block and there's no oil on the outside anyway.
There are no ribs for an oil gallery or cam plug leak to run down there without wetting down the flex plate and a rear main leak should soak it as well.
Did you have a bad rear main leak that was corrected? It could be oil caught in the locator dowel hole from a prior leak or running down the inside of the bellhousing seeping out.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-09-2015, 11:25 PM   #7
Gregski
Gregski's Avatar
guys with a three day weekend coming up I want to tackle this job, but I have no idea where to start, do I pull the tranny off and remove the bell housing and inspect that area, or do I drop the oil pan (again) and that's where the rear main oil seal lives
Old 02-10-2015, 04:35 AM   #8
Chaplain
Chaplain's Avatar
I have no idea where the source of your oil is but just from watching your other post, I don't think you're going stop until you have the engine and trans out. I'm just saying.
Besides that's what I'm doing.
Chaplain is offline   Reply With Quote
Old 02-10-2015, 08:07 AM   #9
homemade87
From the looks of the inside of the bell housing my guess would be the rear main seal . If you have a 2-piece rear main seal I would drop the oil pan and replace it. I see a blue edge on the oil pan . Is that one of felpro one piece gaskets . If so you should be able to reuse it . If you have a one piece seal this is not an option . You will have to drop the trans.
Just take a good look at the top rear of the engine before you do this . Make sure there is no oil coming from a oil sending unit, valve covers or intake seal . My guess there is not . You would see more evidence of oil on the outside of the bell housing . Hope all goes well .
