Old 02-13-2015, 05:16 PM   #1
The Swed
The Swed's Avatar
A sealant that is impervious to gas?
Is there a sealant that is impervious to gasoline? I would to seal off the out side of the fill tube grommet to prevent gas from getting to the cab.
1970 C20 350/TH350, LB
God Bless our Troops
The Swed is offline   Reply With Quote
Old 02-13-2015, 05:18 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: A sealant that is impervious to gas?
Or just don't fill the tank full or make hard right hand turns.
J/K...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-13-2015, 05:26 PM   #3
The Swed
The Swed's Avatar
I just knew someone was going to poke me about this and a vented cap will most likely leak but I'm still taking the those corners hard and fast!
Old 02-13-2015, 05:59 PM   #4
SS Tim
SS Tim's Avatar
Anything I can think of, like PRC or ProSeal, is going to show .
But you could try a tight fitting "O"-ring on the filler neck below the cap and above the gasket to act as a drip stop. It would also help keep fuel off the body during one of those fueling overflow moments.
SS Tim is offline   Reply With Quote
Old 02-13-2015, 09:03 PM   #5
88Ironduke
Just an option that I have not tried.... But when working on aircraft integral fuel tanks we use a sealant called B-2, also comes in a variants including B-1/2(B-half). Its a two part sealant and can be purchased on the internet. It mixes in a tube (takes about 50 strokes to fully mix it) and mixes the entire tube at one time. You typically have a about 20-30 minutes to work it and can set up can be 2 hours to 12 hours@70'F depending what kind you buy. Once mixed it doesn't matter, use a little or lot but the whole thing will harden up. Its stays pretty pliable even when cold, little shrinkage but its expensive. Probably about 40 bucks for a small tube the size of a large tube of toothpaste. I've never fixed a gas tank or filler neck with it but it works great in a kerosene/aviation fuel environment.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 02-13-2015, 10:08 PM   #6
franken
I think a quality gasket sealer or form a gasket will withstand a bit of gas. Years ago I sealed holes poked in a gas can, and the tank on my 69 3/4 ton w/ that stuff.
You can also get some repros of the original rubber part, but Asian rubber doesn't like direct sun.
franken is online now   Reply With Quote
Old 02-13-2015, 10:14 PM   #7
Greasey Harley
Greasey Harley's Avatar
The Right Stuff; I don't know if I would put it on the outside of my truck, but it will seal up [dang near] anything!
Greasey Harley is offline   Reply With Quote
Old 02-13-2015, 10:19 PM   #8
Custom/Ten
Custom/Ten's Avatar
Size:  45.5 KB this says gas resistant
Custom/Ten is offline   Reply With Quote
Old 02-14-2015, 06:55 AM   #9
dirtyjim
dirtyjim's Avatar
before trying to seal the grommet I would make sure the tank is lined up where the filler neck centers up on the hole in the cab. there is a little adjustment on the tank.
what is the condition of the grommet? if its new and the tank is lined up I don't see how gas would get past it, at least on my truck.
when I first bought my truck I had the same problem, a new filler neck grommet and aligning the tank stopped it
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 02-14-2015, 02:07 PM   #10
Fatherflash
Fatherflash's Avatar
88Ironduke
88Ironduke is correct. This stuff is terrific. We also use it all the time and works very well. You can also use AMS-S-8802 to seal a leaking fuel tank. This is the same stuff used to seal aircraft fuel tanks. Can be purchased many places....aircraft spruce, McMaster Carr, ebay.
My other vehicle is unmanned....
Fatherflash is offline   Reply With Quote
