Old 03-27-2015, 12:55 AM   #1
dhawk
truck bed trailer
I was gifted a trailer made from a 60-66 chevy truck bed w/ coil springs and swingarms. It was originally a 1/2 ton that someone tried to beefin' up by welding the springs and making a tracking bar. It currently is very wobbly(left/right) so I was going to start with shocks and a new tracking/traction bar.
I am planning on using it for a wood trailer, so was thinking about adding new springs as well. I have read a few places that switching from 1/2 to 3/4 ton springs is as straight forward as it can be. Any experience/precautions?
I am also planning on using original lights so it looks cool, any changes happen in the run of these trucks that make it so I need to pinpoint the exact year? If so, how do I do that?
Thanks for any/all info!
dhawk is offline   Reply With Quote
Old 03-27-2015, 01:35 AM   #2
jtrichard
Re: truck bed trailer
You DEFINITELY want some good heavy duty shocks like Monroe magnums so it don't ride like its on the ocean ....also you might look for a 3/4 ton rear axle and you cut the axle shafts off, plug the tubes and pack the bearings then you have a GOOD trailer axle
jtrichard is offline   Reply With Quote
Old 03-27-2015, 06:37 AM   #3
PGSigns
PGSigns's Avatar
One thing you may want to think about is what bed it is and what shape it is in. A fleet side with good solid fenders would be better served on a truck. The bed sides are getting harder to find and in good shape are quite valued.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-27-2015, 08:19 AM   #4
Clyde65
Clyde65's Avatar
I agree with PGSigns!
Also if it isnt in decent shape, the 1/2 ton rear axle would be fine for hauling wood. stiffer springs and new shocks would help a lot. One thing you need to look at is how the tongue is grafted onto the frame. I have a 1/2 ton trailer-pickup bed and have hauled wood in it that was a foot or more over the top of the bed ( long bed) this was green wood also. it handled it fine.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-27-2015, 10:26 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
I have a wide side bed/trailer at one time as well. It had 3/4 ton coils and coil over shocks. Was a little bouncy but worked fine...darn shame I sold it.
Old 03-27-2015, 11:19 PM   #6
dhawk
The sides are in decent shape, but it is the middle of the mtns in Idaho, not sure if it is worth trying to sell them.... As far as 1/2 ton springs go - does anybody know if the VRate ones ramp up to as stiff as the HD 1/2? I am going off of lmctruck.com's springs (not sure who manufactures them).
Old 03-28-2015, 01:01 PM   #7
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Generally GM would use the next series up springs and call them Heavy Duty. So stock 3/4 ton springs are heavy duty half.
