engine mount question
I'm getting ready to swap an LS engine (5.3L) into my '80swb C10 which currently has a 250 six. Are the engine mounts that are bolted to the frame in the same location for the sixes and V8's, or are the locations specific to the engine? Thanks
Re: engine mount question
Dirty Dingo is your friend!
![]() Join Date: Dec 2012
I used Early Classic Enterprises LS conversion kit. They fit great!!!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Gents, what I'm starting with is engine plates from Tejas-Steelworks and stock Chevy clamshells. I just need to know if the frame mounts in my 6 cyl. truck are in the same position as a V8 truck. Thanks
I would say you will have to test fit because they make so many variations of mounts.
#6 | |
meowMEOWmeowMEOW
In my case, I needed to move my engine forward about 1" while using '66 I6 perches and LS adapter plates, to feel comfortable with the room to work. You could probably go another 1/2" back, to be "perfect". Every combo will be a little different. I'm unaware of the Tejas plates, but I'm guessing they work like every other swap-plate. I'd suggest that you unbolt the perches from the kmember, bolt the plates and mounts all up to the engine, then set the engine in slowly and see where it and the perches WANT to line up. Some of us also use 1 existing frame hole, then drill another (forward or aft) to allow for further-offset mounting if you really need it.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#7 | |
And welcome to the board!!!post some pictures!
Again, thanks for the response. First, Tejas Steelworks is a custom fabrication/hotrod building shop in Texas, run by Scotty Baccus. He laser cuts LS mounting plates that allow the use of the clamshells and puts the engine in position so that the stock ac compressor can be used in its' original location without resorting to crossmember modification. He also has published an LS installation guide for the square bodied trucks. Check him and the guide on Facebook.
I took some pic's of my engine mount (pass.side) so that maybe you can enlighten me a little. ![]() ![]() I'm not seeing any provision for changing the mount location, either fwd. or aft. I have seen in the pre '73 trucks that you would change the frame pad position for whatever engine you had, but my truck has me stumped. Concerning pic's, check out my new member posting Later... Lee |
Lee,
I just noticed that your swap vehicle is an '80 my comments are for pre 73' sorry about that as I am not sure about the square bodies... I will look at the pictures when I get home. My work computer will not allow me to see the pictures from a link like photobucket and other online photo storage sites. Only uploaded images...
meowMEOWmeowMEOW
Lee, I wrote everything from the perspective of the 63-mid70's swaps, so its good advice-just about the wrong truck haha.
It looks like yours are bolted directly to the crossmember without using an additional perch. With that being the case, the location won't change I6 to V8, only the engine-side plate would change. Something like this would be whats bolted to your engine. The mount would stay where it is on the kmember.
Thank you, sir. Maybe another piece of the LS puzzle is solved
Later... Lee |
