![]() Join Date: Jul 2007
Wire Diagram Question
Does anyone have a good wiring diagram for a 1966 C-10 with gauges? I see lots of diagrams but they seem to be Idiot lamp ones. I have a gauge dash to install but a few wires are damaged so I want to see what is needed to fix them. Thanks
Re: Wire Diagram Question
Bumping on account of I need it too. "Restored" a set of gauges to replace my idiot lights, but it came without any harness. Can't find a good schematic anywhere. I know what gets landed where, but I'd like to use factory wire colors If possible.
Ttt
The 1966 diagrams can be found in the Chevrolet Truck Shop Manual 1966 supplement. Re-prints of this manual are available from various vendors. There are also some diagrams in the 1960-1966 Chevy Truck Factory Assembly Instruction Manual (the one with the white & yellow cover reprinted by Golden State Pickup Parts).
The gauge clusters were standard equipment in most of the larger medium/heavy duty trucks. As a result, you have to look at the C/L/M 60-80 series diagrams (not the C/K 10/20/30 diagrams) to see the gauge cluster wiring. Here's a page I wrote about converting Dad's 66 C10 from warning lights to gauges --> http://rmcavoy.freeshell.org/Truck_gauges.html It has scans of some of the factory diagrams (both warning lights & gauges). I've been working on an update to my website but haven't gotten around to uploading it yet. But here are a few of the diagrams I've drawn for the update. I used the factory 64-66 wire color codes. ![]() ![]() ![]() ![]() I haven't finished drawing up the diagram showing exactly where all the wires connect to the backs of the gauges. Also note that the engine & alternator/headlight harness diagrams show "4A inline fuse recommended". These fuses were stock equipment in the ammeter wiring on 67+ GM trucks. I highly recommend adding them to 64-66 trucks when using the stock "BATT" gauge (ammeter). |
