![]() Join Date: Oct 2007
fuel line info needed
I’ve got a 2002 6.0L engine going into my 70 with the fuel tank and pump in the rear. I’m looking for suggestions on where to purchase my fuel supply and return lines and filter.
Thanks |
![]() Join Date: Sep 2014
Re: fuel line info needed
I used the info in the FAQ on Fuel and bought most of my stuff from Summit and Amazon which ever was cheaper. It's still not cheap but it worked out great.
10-4 thanks. I'll go there, forgot about that resource.
I went to the pick and pull with a tubing cutter and cut 6 ends off of donor trucks, I left enough steel so that I could use double flares and inverted brass connectors. You can borrow the double flare tool from AutoZone or orylies. Napa sells the brass inverted connection s. Yo Cain use stock lines or do like me. I bought a 25 foot roll of 3/8 coated fuel line cheap at auto zone. I run a inline fuel filter from Wal-Mart. The 3/8 push connectors fit right on it. I'm also running a 02 camaro fuel tank and pump
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
That is a smart way to get it done! Thanks
I used the Dorman nylon fuel line kit and summit heat sleeve (on the run up to the back of the engine), it is just like the factory stuff on new cars.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
Got a pic of the filter or a part number? Is it 3/8" quick connect on both ends? Im planning on the Dorman nylon line as well and I'm trying to sort out what type of filter to run after the Walbro 255.
Here you go
