Old 03-23-2015, 08:12 PM   #1
cheessee
New brake line question
My truck came with no brake lines and it has a front and rear suspension swap from an 80s c10 that being said it has disc brakes in the front and drums in the rear.. Here is my question.. I'm looking at the brake line sets and they sell them with power drums or manual drums.. I'm going to be running power brakes.. Do I buy the set for power drums? Thanks in advance..
1963 GMC swb sbw 5.3/4l60e porterbuilt
From middle Tennessee
60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details..
cheessee is offline   Reply With Quote
Old 03-23-2015, 10:27 PM   #2
60ShortStepGMC
60ShortStepGMC's Avatar
Re: New brake line question
With your current configuration you'll want a brake line kit for disc/drum (e.g disc's in front, drums in rear). From what I've read you'll want to incorporate a proportioning valve in this setup.
Power drums is for drum/drum with a power boosted master cylinder. Manual drums is for drum/drum with the stock (or no booster) master cylinder.
60ShortStepGMC is offline   Reply With Quote
Old 03-24-2015, 12:34 AM   #3
spookylynx
spookylynx's Avatar
I went down this road kinda too, and what I came up with that should work is.. a disc/drum MC for a '73 C10, a booster for a '73 C10, the power brake adapter bracket from Captain Fab, and a proportioning valve from CPP. It's a non adjustable valve, I think its 70/30... but cant recall.
There are some good brake write-ups in the FAQ section, that's where I did all my research.
spookylynx is offline   Reply With Quote
Old 03-24-2015, 10:41 AM   #4
cheessee
So a brake line kit from the 73 bodystyle will fit the 64 frame?
The pre bends is what I'm wondering about
Old 03-28-2015, 12:53 PM   #5
spookylynx
spookylynx's Avatar
That, I don't know, probably not. I am bending and running all my own new hard lines.
Old 03-28-2015, 01:11 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
I doubt there is a pre-bent kit that will do what you want.
Keith
Convert to disc brakes.
Old 03-28-2015, 01:14 PM   #7
lolife99
lolife99's Avatar
You can probably use the frame rail lines and some conversion hoses to get you to the calipers,... but you will have to bend up some lines to get you to your new M/C and prop valve.
Keith
Old 03-28-2015, 10:35 PM   #8
spookylynx
spookylynx's Avatar
Bending lines really isn't that hard. I am pretty new at it, just get a good double flare tool and practice a couple times with it. And take your time. It's not that bad
Old 03-29-2015, 12:59 PM   #9
cheessee
Alright thanks
