Old 03-31-2015, 01:28 PM   #1
donthekawguy
donthekawguy's Avatar
replacing rivets with bolts
Anyone ever do it? I know there is no reason for it but I might be picking up a rolling chassis and will be taking it all apart. I think it would look cool having some grade 8's holding it all together.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-31-2015, 01:34 PM   #2
1strong63
1strong63's Avatar
Re: replacing rivets with bolts
hi you might have one reason to replace them if you weld close to one inch of a rivet.
i've done a few crossmember modification on my 63 C10 and i used grade 8 bolts with two washers and a nylon insert jam lock bolt everytime.
1strong63 is offline   Reply With Quote
Old 03-31-2015, 01:52 PM   #3
1963c-10
1963c-10's Avatar
Did my whole chassis in grade 8 wherever I removed rivets. And they are such a joy to grind out!!!
1964 Short bed trailer
Old 03-31-2015, 02:11 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Yep, of the rivets I've removed for modifications, replacing damaged/corroded parts, I've used regular grade 8 nut/bolt fasteners.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-31-2015, 02:46 PM   #5
Keith Seymore
Keith Seymore's Avatar
Must be something in the air lately:
http://67-72chevytrucks.com/vboard/s...d.php?t=665284
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 03-31-2015, 08:23 PM   #6
vince1
I think they stay a lot tighter with rivets. I sure don't remove them unless I have to, like with ball joint replacements. The bolts are no doubt strong but they don't fill the voids and shrink like a hot rivet does.
vince1 is offline   Reply With Quote
Old 03-31-2015, 08:52 PM   #7
Keith Seymore
Rivets were cold headed in the assembly plant (not heated).
K
1979-1986
1986 - 2019
Old 04-01-2015, 01:44 AM   #8
Captainfab
60-66 Nut
I prefer to use the prevailing torque, all steel lock nuts.
Old 04-01-2015, 05:13 AM   #9
pimpston65
pimpston65's Avatar
turn on a dime, are there any rivet kits i can use to replace cut out rivets? i was gonna shape the heads of grade 8 bolts to make it appear to be rivets. any help would be great!!!
pimpston65 is offline   Reply With Quote
Old 04-01-2015, 10:20 AM   #10
53Sparky
53Sparky's Avatar
I would think that reshaping the heads of a grade 8 bolt would defeat the purpose of using a grade 8 bolt. Not sure on the science, but my intuition says that the heat of grinding coupled with the removal of material would not likely make them stronger.
I'd hate to have something important fail while you're out on the road.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 04-01-2015, 10:26 AM   #11
1963c-10
1963c-10's Avatar
And if the bolts ever became loose, youd be unable to tighten them too pimpston65.....
Old 04-01-2015, 11:26 AM   #12
SayBye
SayBye's Avatar
Such a joy!
Didn't take long but still a pain. I just did this two nights ago on my ebrake crossmember, had to remove it to fit my t5 in. Im bolting it back on with grade 8 3/8" bolts and nyloc nuts
SayBye is offline   Reply With Quote
Old 04-01-2015, 11:50 AM   #13
argonaut
argonaut's Avatar
I had the whole frame apart on my 66. Cut out every sibgle rivet. I redrilled through all the holes to 7/16 and used grade 8, 7/16-20 fine thread bolts with hardend flat washers and grade 8 nyloc nuts. I started with 3/8 but the 7/16 bolts can handle much more torque and thus imoart much higher surface contact friction.
The compromise is that these still dont work as well in shear as the rivets do. But I rrally didnt have any other choice unless I wanted to weld all the crossmembers to the frame. Its been holding up okay so far.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 04-01-2015, 03:35 PM   #14
urmyboyblue
Button head cap screws have a rounded look like a rivet on the head if that is what you are looking for. I would drill the hole to be tight (5/8" for a 5/8" bolt) on the next size up bolt if you are wanting to go that route.
urmyboyblue is offline   Reply With Quote
Old 04-01-2015, 04:15 PM   #15
1963c-10
1963c-10's Avatar
Originally Posted by SayBye View Post
Such a joy!
That's not so bad....try the bellhousing crossmember with the cab installed. Best one yet!!!
Old 04-01-2015, 05:25 PM   #16
pimpston65
pimpston65's Avatar
thanks for the info
Old 04-01-2015, 09:22 PM   #17
vince1
Years ago I did some work on a Model A frame and cross member. I used a Chrysler wheel bolt with the dish in the head and welded it on to the end of a rivet snap. After heating the rivet red it did a really nice job of rounding the end.
But if I ever had to do one again I'd use the bolts.
