Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-24-2015, 12:11 AM   #1
scrappy70
scrappy70's Avatar
Fuse Block
I have the original fuse block, but want to add a cig lighter, glove box light....should I update the entire fuse block? When it says that it is a 13 circuit block, does that mean it had 13 different connection?
scrappy70 is offline   Reply With Quote
Old 10-25-2015, 04:00 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Fuse Block
subbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 10-25-2015, 06:01 PM   #3
ray_mcavoy
Re: Fuse Block
A cig lighter and glove box light were factory available options. So there is a provision for them to plug directly into the original fuse box. Look for the terminal labeled "CIG" that's between the "AIR COND / HEAT" and "TRAFFIC HAZ" fuses.
That terminal is un-fused but it is protected by a fusible link in the feed wire (fusible link is located in the engine compartment). I don't think the factory cig lighter had a separate inline fuse but adding one would be a good idea.
ray_mcavoy is offline   Reply With Quote
Old 11-02-2015, 08:10 PM   #4
scrappy70
scrappy70's Avatar
Re: Fuse Block
Thank you. I did locate the connections but there is something else plugged into the CIG and I need to locate where the wire leads to. Thanks again.
