Old 09-05-2012, 11:19 PM   #1
gono
gono's Avatar
Battery size suggestions
I'd like to use the stock battery tray and hold down in a 1955 3100 stepside. What would you guys suggest as a good battery to use? I'm running a 350 SBC/700R4, A/C, descent size stereo, umm not sure what else to mention.
55' 3100 big window
gono is offline   Reply With Quote
Old 09-06-2012, 12:57 AM   #2
parkwood
parkwood's Avatar
Re: Battery size suggestions
look for a battery that has good cranking amps... Group 24 seems to fit the trays ok but you may be able to go a little bigger. just get the ruler out.. But a lot cranking amps is what you're shooting for..
parkwood is offline   Reply With Quote
Old 09-06-2012, 07:19 AM   #3
Russell Ashley
Russell Ashley's Avatar
If you want to use an original style hold down that goes around the top edge of the battery you'll need to shop around for a battery that doesn't have the built in handle. Those won't fit the bracket.
Russell Ashley is offline   Reply With Quote
Old 09-06-2012, 10:48 AM   #4
mknittle
mknittle's Avatar
I like the optma red top, it is gell cell and wont leak and is zero maintanance.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 09-08-2012, 09:24 PM   #5
TX58
I got mine from Walmart, the Maxx series. I measured the stock battery tray bottom and they had one that fit perfect. Have no problem cranking my stock 283 V8 at all. Also, the stickers come off easily leaving a clean black battery.
TX58 is offline   Reply With Quote
Old 03-17-2015, 09:10 AM   #6
roger55
roger55's Avatar
What group size was that battery?
I've got the factory box in my '57 and a set of new repro hold-down bolts and would like to have a battery that fits right. I need a battery that fits the box size and is the right height.
The new hold-down bolts I got are too long for the battery I've got in it now as the battery isn't tall enough.
roger55 is offline   Reply With Quote
Old 03-17-2015, 02:31 PM   #7
OrrieG
OrrieG's Avatar
Group 24 or 34 (top posts) will fit as well as 78 (side treaded posts) Most battery companies make a 34/78 with both sets of posts. Check the battery tray size as some higher amp Group 24 are longer and wider and will not fit.
Old 04-24-2015, 05:37 PM   #8
pvienneau
pvienneau's Avatar
Guys, I'm late to the party on this one, I picked up a battery based on the group recommended in this thread. OOPS! I have a AD that is only about 9 inches and the 24/34 are 10 inches. I'll return it tomorrow, but I like the 800 CCA it has.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
