Old 04-16-2015, 04:57 PM   #1
87Skier
87Skier's Avatar
TH350 to 700r4 swap
Well, because I can't just leave my stuff alone and the engine feels pretty gutless from a stop I'm already planning on swapping in a 700r4 and changing out the front/rear diff.
I know its about 3" longer, so what have you guys done? Engine forward, or transfer case back? How did that work out?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 04-16-2015, 06:37 PM   #2
jaros44sr
jaros44sr's Avatar
Re: TH350 to 700r4 swap
Engine forward is the best, no fooling with the driveshaft lenghts
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-17-2015, 08:46 PM   #3
warbucket
warbucket's Avatar
I'm with Jim, I moved the engine 2" forward then used the Advanced Adapter 1 3/4" spacer to mate the 205. I relocated the transfer case support 1 3/4" back. I have a 2 1/2" lift and a 14 bolt rear and had to set the pinion angle so I moved the rear back 1" to center the wheel in the wheel well. I can still run the stock drive shafts but I set the pinion for a CV shaft from Tom Woods.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 04-17-2015, 09:18 PM   #4
elkniks
elkniks's Avatar
HAAAAAAAAA! I really did laugh out loud when I read that. How many times have you looked at someone who just called your truck a Bronco and had to count to 10.
elkniks is offline   Reply With Quote
Old 04-22-2015, 12:17 PM   #5
IwantaK5
Is your trans a 700r4? I did the same trans swap and i didnt need any spacer. Just the proper output shaft from AA.
IwantaK5 is offline   Reply With Quote
Old 04-22-2015, 10:00 PM   #6
warbucket
warbucket's Avatar
yes, 700r4, the trans I had was already rebuilt and I didn't want to send it out to change the shaft so I took the cheaper option.
Old 04-23-2015, 11:27 AM   #7
87Skier
87Skier's Avatar
That was going to be my next question! I have a broken 4L60E on my garage floor right now and the only difference I can spot in dimensions is the output shaft.
So I can pickup a shaft for a 700R4, put that in and will directly bolt in place of a TH350, or it still slightly longer? Either way, the engine will be going forward. Sure would be nice to actually be able get to the distributor.
Old 04-23-2015, 09:16 PM   #8
warbucket
warbucket's Avatar
It will bolt in. With the spacer you have to trim the output shaft so it won't bottom out in the transfer case. I heard some guys had clearance issue's with the CV joint on the front driveshaft hitting the trans pan when using the AA shaft.
Old 04-24-2015, 10:32 AM   #9
JMac11
JMac11's Avatar
We trimmed the shaft, no spacer. Just test fit to make sure splines are fully machined far enough back.
JMac11 is offline   Reply With Quote
Old 04-29-2015, 04:20 PM   #10
87Skier
87Skier's Avatar
Alright, I checked my splines in the transfer case adapter and it seems I need a 27 spline, so that's all good. I had considered trimming the shaft. Is the case of the 700r4 actually any longer? Or does the extra length come from the shaft?
Old 04-30-2015, 03:53 PM   #11
JMac11
JMac11's Avatar
We still had to move the motor forward, unbolted cross member slid everything up
Old 04-30-2015, 08:02 PM   #12
87Skier
87Skier's Avatar
I was thinking it was a little longer. How much longer is it actually? Just trying to get an idea of how close the engine will be.
Old 05-01-2015, 09:32 AM   #13
JMac11
JMac11's Avatar
I could still run a fan, cannot say if it was the "right" Blazer fan or not. Same thing on fan shroud. Only hard part was loosening the exhaust clamps to let the engine move.
Old 05-06-2015, 04:22 PM   #14
tismy65
will the transmission mounting support be the same as the 350
tismy65 is offline   Reply With Quote
Old 05-11-2015, 03:26 PM   #15
87Skier
87Skier's Avatar
I converted to an electric fan. So I'll need to hack up my fan shroud some more but no problem.
Someone correct me if I'm wrong here, but the 700r4 and TH350 both relied on the engine and transfer case as support. There are no actual mounts anywhere on the transmission case.
