Old 05-01-2015, 07:53 PM   #1
lowrodderchev
lowrodderchev's Avatar
what size of wheel?
So I'm thinking of buying some Mickey Thompson classics for my 1975 blazer. She's got a 4 inch lift sitting on 35x12.5x15 stock ralley wheels. I'm going to use my same tires but was wondering should I get a 15x8 or 15x10 wheel?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 05-01-2015, 09:01 PM   #2
bmchevy1979
bmchevy1979's Avatar
Re: what size of wheel?
I would go 15x10 these trucks look better with a wider stance and those rims look better deeper only thing you will have to worry about is the tires rubbing
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 05-01-2015, 11:41 PM   #3
'68 Newtricks
'68 Newtricks's Avatar
While my rims are 11" and second set is 10", I also run a 15.5" wide tire. I personally don't like rims that are close to the width of the tire, looks funny to me. I like to see a fatter sidewall as this helps protect the rim while offroading, it also helps when you air down. More than that, I think it just looks better.
So I'd have to go with a 15x8 for the tire size you currently have. If you are towing more than anything, I think the wider 10" handles the weight better.
Here is my father truck with 35x12.5 on 10" rims. Next one is my truck with 38x15.5 on 11" rims.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-01-2015, 11:55 PM   #4
lowrodderchev
Nice blazer, yeah after looking at mine the rear of the front tire is a little too close to run a wider wheel
Old 05-04-2015, 05:09 PM   #5
Ski-me
Ski-me's Avatar
These are 15x10 MT with 35 x 12.5 tires.
I prefer the 15 x 8's or 15 x 9's if possible.
15 x 10's allows just a little too much rim exposure for my liking.
How do you like the look on the 15 x 8 rally wheels??
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 05-04-2015, 05:21 PM   #6
lowrodderchev
There cool but Im leaning toward 15x10 I want something that sticks out a bit more
Old 05-04-2015, 05:24 PM   #7
lowrodderchev
These the ones in looking at rap em in my general grabbers I have now
Old 05-04-2015, 05:32 PM   #8
lowrodderchev
My rallys now
Old 05-16-2015, 09:34 PM   #9
lowrodderchev
Finally found me some wheels
Old 05-16-2015, 09:35 PM   #10
lowrodderchev
Now the problem they fit but when I spun them on the front the weights hit. Any suggestions? Thanx guys
Old 05-18-2015, 01:19 PM   #11
lowrodderchev
New wheels are on
Old 05-18-2015, 02:10 PM   #12
68Timber
I know the pieces fit
68Timber's Avatar
Looks good!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-18-2015, 03:56 PM   #13
lowrodderchev
Thanx bruiser I'm diff liking the black tires now
Old 05-19-2015, 02:30 PM   #14
Jonboy
Slots go on anything!
Ski me and Lowrodder, what lift are you guys using on your trucks with the 35's? That, and how tall are they at the roof? I am getting ready to lift my '74 Jimmy, just not sure if I want to do 33's or 35's. It needs to fit in the garage with the top off, ideally.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-19-2015, 03:01 PM   #15
Ski-me
Ski-me's Avatar
Mine has a 2.5" lift on it with the 35's. Definitely tight! It will also depend on the actual tire you get. Not all 35" tires are truly 35" tall. Those are "nominal" type sizes and also can vary depending on width and rim size.
With the 2.5" lift I do rub on the inner front fenders when turning and hitting a bump. Can be driven without rubbing but only on the street. Off road, I'd be hitting a lot more!
- Jeff
Old 05-19-2015, 03:59 PM   #16
Jonboy
Mine will probably be a mall crawler too. I can't afford the Trans Am I want, and the top comes off of the Jimmy, so it will do for now. Being 4WD, it has to go up. I will be running 3/4 ton axles, so I haven't bought wheels/tires just yet. I was figuring 16x10 wheels, and either a 33/12.50 or 35/12.50 BFG (probably All Terrain). Really going for looks at this point. Your truck looks great the way it is set up. I really figured it was a 4" lift.
Old 05-19-2015, 04:32 PM   #17
lowrodderchev
mines a 4 inch i did have to trim my fenders inside a bit to clear the new wheels there 15x10
Old 05-19-2015, 04:34 PM   #18
lowrodderchev
and mine don't fit in the garage but i haven't had any issues at the mall but i will say when I'm there I'm driving slow and ducking
