Old 05-22-2015, 12:53 PM   #1
Jobe72
Jobe72's Avatar
Wiper motor buzzing
Last night on my way home my wipers stopped and the motor made a loud buzzing noise. Got home and tried to help the wipers, they moved a bit and then locked up again. Going to lube all the moving parts but assuming motor might be on it's way out. Thoughts? Been working just fine lately, and we've had lots of rain.
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 05-22-2015, 03:54 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wiper motor buzzing
Is there any rust out where the wiper shaft goes through the firewall? If there is it could be binding up. You will probably need to take the cowl vent off and remove the wiper linkages from the wiper motor arm and see if the motor runs OK then. Also, while it is apart move each of the linkage rods by hand to see if they are free.
LockDoc
Leon
Old 05-22-2015, 04:35 PM   #3
RodnRudy
RodnRudy's Avatar
You might want to make sure you've got a good ground to the motor. That happened to me once on a 95 Chevy truck. I ran a dedicated ground from the motor to the fire wall and that solved the problem. The same thing happened on a 87 Dakota pickup I had. Go figure.
RodnRudy is offline   Reply With Quote
Old 05-22-2015, 04:39 PM   #4
Jobe72
Jobe72's Avatar
No rust issues, this truck is pretty much rust free.
I'll check the ground. Been driving the truck frequently and wipers have been working fine, just happened a few blocks from home last night.
