55-59 Engine Placement Question - V8 Swap
Hi,
Currently building a 57 GMC truck and having issues with engine placement in terms of the distributor hitting the firewall and potential for the TH350 not going to fit. Pics show issues. I put in a sbc in the truck using a Trans Dapt motor mount kit. I based the placement of the engine. To determine placement, I bolted a cast bellhousing to the back of the engine, then bolted that down to the stock bellhousing crossmember ( as I was going to use a 5 speed before). Then I leveled the engine intake and bolted the Trans Dapt motor mounts to the frame. Engine fan is sitting 5 inches from rad. Large HEI GM distributor touches firewall with cab bolted back down. TH350 trans that I am now going to use seems that it will be a tight fit under the floor. Pics show this. Trans needs to come up another 2 inches and go forward another 1 inch or so. Question is, did I make a mistake basing the placement of the engine off the bellhousing crossmember (which is now removed so that the auto trans can go in)? What distributor should I use? Trans Dapt mounts firewall / trans pic Any thoughts or help would be sincerely appreciated. My "expertise" is 67-72 trucks. I'm still learning on the TF ones! Cheers! Enjoy your build.
1967 C-10 250 I6 w/ TH350 3.08 10 bolt HUGGER ORANGE aka "The General" '57 GMC short step REGINA SPECIAL 2013 CREW CAB SILVERADO 5.3 6 SPEED Z71 WHITE DAILY DRIVER "When you have eliminated the impossible, whatever remains, however improbable, must be the truth." ~Sherlock Holmes "Deeds will not be less valliant because they are unpraised." ~ Aragorn |
Re: 55-59 Engine Placement Question - V8 Swap
The T-350 is bigger than the stock 3 or 4 speed trans. You need to work on the floor or move the engine. Its not hard to modify the floor. I have a 350 with T-400 in my 56 and did not need to modify the floor, so mine is lower or forward of yours.
#3 | |
Anyone else with experience here or the same situation?
I used a Camaro sub and had the engine bolted to the trans I was using when I test fit. I have the engine set back a little from where it set in the Camaro. I had to cut out a little in the subframe for the fuel pump. After adding some metal back in, you can't tell where it was modified.
55-59 chevy and gmc trucks came factory with v8 motors, while there are some differences in gmc and chevy frames
the cabs are the same, a sbc and th350 will fit without any floor or firewall modifications the crank pulley should be very close to the x-member, i suspect your motor is too high post a pic truk came with a 350/350 that was poorly installed on the original front motor mounts with the sheet metal on the truck i was able to fab up these side mounts ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
not sure if the x-members are the same, but just found this in dan in pasadena's build
![]() valve cover to firewall clearance reference ![]() no floor modifications ![]() and a th350 installed with the stock rear x-member (orrieg did this too) ![]() lots of good pics in his build thread http://67-72chevytrucks.com/vboard/s...=463698&page=5
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer Last edited by _Ogre; 06-03-2015 at 10:41 PM. |
![]() When I installed my engine, I suspended it on a cherry picker and put the core support, radiator and fan shroud on so I could get the fan to sit in the Shroud without any modifications. Just a thought.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi |
Thanks for the input Gents!
Can Dan in Pasadena or Truck Nut measure your fan blade to rad clearance for me? I might just be too high in the frame. And like Truck Nut says, I might just re-suspend the engine/trans and redrill. Is there a recommended distance from fan blade to rad that I should observe? What distributor should I use? Stock GM HEI or something smaller? Thanks!
Strider,
Distance from your shroud will be determined by the type of fan you are using. Mine looks like it sticks out about 1.5" but when the engine is running those fan blades flatten out and are almost even with the shroud. ![]() I made my mounts based off this design: ![]() And the placement on mine turned out pretty good. I had to drill one hole on each side. Drivers Side, ![]() ![]() Pass. Side, ![]() Sorry I don't have any better pictures. But hopefully that will give you an idea how I did it. I have used the Mallory Unilite distributor since this engine has been in the truck. About 15 years now. I have about an inch between the firewall and distributor. It has the same size cap as the old points style did.
Somehow, the idiots survive despite their best efforts to kill themselves. - dcozzi Last edited by Trucknut57; 06-04-2015 at 02:47 PM. Reason: Forgot something. |
My 57 was an original v8 truck but I moved my motor and original bell housing mount
2 1/2 inches forward so as to have plenty of firewall clearance with full sized HEI distributor. Moved core support and radiator to the 6 cylinder mounting position and still have to use a spacer on fan to get close enough to radiator. ![]() ![]()
1957 3100 ![]() 1950 5 window Last edited by starterman99; 06-04-2015 at 03:22 PM. |
Thanks Starterman, From your pics I see the difference in the shroud you have and the one in the post before you. Yours is factory then, right? The one above is aftermarket I assume. So you had to move your engine forward in order to have the fan blades fully or mostly inside of the shroud, right? Your truck looks great. Good to know about the distributor too. I could move my engine down and forward easily enough I suppose. What's a couple more holes in the frame, right? I just like the current position of where the fan sits in relation to the rad - not the distance from it, but the fact that it looks centered in the rad.
What is the 6 cylinder mounting position for the rad for these trucks? My truck was a 6 cylinder so I suppose the rad wall and rad are in this position on my truck?
#13 | |
Thanks again Trucknut, Your truck is great too. I like the mounts you made for the engine. There is nothing wrong with the TransDapt ones I used and there are several options for engine mounts for these trucks which is great. I see several people have used crossmember style mount which would likely add strength to the frame. I'm assuming using a manual trans with the engine based off the bellhousing mount is a non-issue and only becomes an issue when an automatic is used. Perhaps the autos are more robust in size thus requiring the engine moved forward / down from the original bellhousing position. Any thoughts on this?
#14 | |
#15 |
On original V8 trucks the radiator support is about 5'' closer to the firewall. In the previous pictures you can see the hole in the inner fender about even with the shroud where the radiator support was bolted originaly.
1957 3100 ![]() 1950 5 window |
#16 |
Are there corresponding mounts on the frame for the rad wall to bolt to then?
#17 | |
Or is the rad itself spaced from the rad wall on factory V8 trucks?
#18 |
The mounting brackets on frame are moved and radiator wall or support is moved then it has a sheet metal filler pnael on top to cover the gap that is from hood latch to radiator. The radiator is not spaced from rad wall.
#19 |
Here are the FAM drawings of the factory v8 mounts and radiator tin. Also a photo of my mounts and valve cover and HEI clearance. I placed my engine by installing the block, transmission and transfer case in place with the front drive line connected (expensive to modify). I then raised the assembly so that the carb base was level, which gives the engine, trans etc. a 4 degree down angle, and the TH350 pan cleared the original rear cross member and trans bellhousing did not hit the bottom of the cab. I also dropped in a point dist to check clearance. Front mounts were fabbed from 1/2" steel plate using one existing crossmember hole and another drilled. Rear transfer/transmission mount from the 74 donor was used with extensions to bolt to the side of the frame. I went with the front mounts to avoid clearance issues with the exhaust and steering. I kept the radiator in the stock 6 cylinder place and found a fan shroud that works (70 Mustang of all things). This was all done in 1985 before the internet based on a local truck that had a similar conversion.
