Old 06-04-2015, 01:14 PM   #1
summitflier
summitflier's Avatar
Cab Gas Filler Hole
Anyone who is moving their cab mounted tank to under bed?
What do you do with the old cab hole?
Weld in a piece of sheet metal?
Another thought I had was to saw off the fill neck from the (internal) tank
shove it through the rubber grommet and put a gas cap on it, and make it
look like I still had an internal tank.
Other ideas? An easier way?
summitflier is offline   Reply With Quote
Old 06-04-2015, 01:27 PM   #2
hamjet
hamjet's Avatar
Re: Cab Gas Filler Hole
"Another thought I had was to saw off the fill neck from the (internal) tank
shove it through the rubber grommet and put a gas cap on it"..... just make sure you weld or glue the cap to the neck if you do this. someone might borrow your truck and try filling the tank. Most people weld a patch there.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 06-04-2015, 01:30 PM   #3
WarMonger
WarMonger's Avatar
LMC truck sells a pre-cut sheet metal piece that is a good fit. buy that and weld it in.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 06-04-2015, 01:44 PM   #4
H20cooled
I just did like you mentioned I cut off the filler neck but I welded the bottom of the filler next up tight and painted it black. Its not in the truck yet but it should work good.
H20cooled is offline   Reply With Quote
Old 06-04-2015, 01:55 PM   #5
davepl
davepl's Avatar
Whoa. Isn't anyone worried about sawing a fuel tank?
When I did it once for my Camaro, I took the tank out and filled it with water. If it's been empty for years, maybe. But gas fumes plus spark will ruin your whole day.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-04-2015, 01:57 PM   #6
H20cooled
The tank had been completely emptied and sitting for 6 months outside and open. I then filled it with water and made sure that nothing else was in there. I had no issues after doing this with cutting it. But yes need to be careful with doing this.
Old 06-04-2015, 02:06 PM   #7
cdowns
cdowns's Avatar
You can easily put a rubber chicken into that hole
Old 06-04-2015, 02:24 PM   #8
Bigdav160
Bigdav160's Avatar
I welded mine up but I painted the truck after that.
With that patina I'd put a filler neck with a red rag shoved in it for effect
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-04-2015, 04:03 PM   #9
Jonlopes
Wow, did anyone else laugh out loud after reading this? The visuals...
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-04-2015, 04:39 PM   #10
truckster
truckster's Avatar
I wonder how many gallons that would take. I guess it would depend on how good your door seals are, and whether you have rust through the floor.
truckster is online now   Reply With Quote
Old 06-04-2015, 07:00 PM   #11
rustrunner
+1 for the RED RAG solution
1970 Custom Camper/20
1959 Morris Minor 1000
1953 Dodge B-4-KA
1953 Fruehauf 30' Lowboy
1928 Cat 30
1939 TORO Bullet Tractor
rustrunner is offline   Reply With Quote
Old 06-04-2015, 11:23 PM   #12
hammerholley
Unhappy Re: Cab Gas Filler Hole
I put a horn button! Awsome it says chevrolet division. No pick. Don't copy if your in 36117...
I will find out you know. jk
hammerholley is offline   Reply With Quote
Old 06-04-2015, 11:26 PM   #13
hammerholley
You could put a nos energy drink can in it like you are filling up. But then you would be taking my other idea...thats okay some people just dont have it. I cant read.
Old 06-05-2015, 12:01 AM   #14
71swb4x4
71swb4x4's Avatar
I left the rubber grommet on it, put the gas cap up to the grommet, put a 6" bolt on the back side, and used two zip ties to attach the tabs on the gas cap to the long bolt. No need for it to be a bolt, anything about that length would work, a pencil, dowel, branch, etc.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-05-2015, 12:36 AM   #15
Fitz
I personally like the rubber chicken solution proposed earlier!
Fitz is offline   Reply With Quote
Old 06-05-2015, 12:08 PM   #16
Userone
Userone's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=250995
Userone is offline   Reply With Quote
Old 07-13-2015, 01:16 PM   #17
summitflier
It has been mentioned that a few places sell patch panels for this.
Does anyone have a link?
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
Old 07-13-2015, 01:23 PM   #18
In The Ten Ring
My uncle's late 1960's Lincoln was rear-ended by a large truck and the gas tank was punctured.
My dad welded up the punctures while the tank was on the car and 1/2 full of gasoine.
How did a man manage to do that without an explosion? Easy! The Fire Triangle.
Gasoline (like most everything else) needs three things to burn. Take away any of the three and it cannot burn. Dad ran a hose from his (now my) truck's exhaust to the tank nozzle. Then he idled the truck before and while he was welding. Carbon monoxide fumes displaced the air (containing the essential oxygen) and the gasoline could not burn or explode.
The coal mine where my dad worked didn't call him "The Doc" for nothing!
In The Ten Ring is offline   Reply With Quote
Old 07-13-2015, 01:43 PM   #19
summitflier
Finally found a place.
http://www.azproperformance.com/AVS-...-GDFPGM67.html
SKU SM-GDFPGM67
$25.00
http://www.ebay.com/itm/67-72-chevy-...item23545dc1e8
$14.95 (only has 1 left)
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-13-2015, 03:01 PM   #20
shawley
I just picked up a chrome gas cap from LMC, and then we took it apart, and fabbed up a mount from the rear to hold it in place. My truck's paint was good and I didn't wanna do any body work and fill it etc. the original rubber worked nice to seal it up.
shawley is offline   Reply With Quote
Old 07-14-2015, 09:05 PM   #21
jdalexa84
I have a friend who put his antenna there. It was an electric one. Looked awesome.
jdalexa84 is offline   Reply With Quote
Old 07-14-2015, 09:23 PM   #22
H20cooled
I love my dad's suggestion and I might just have to try it. My filler is just the neck welded closed with the cap on it, he said to put one of those spring snake things that were in the old can of nuts. It would be a good funny joke.
Old 07-14-2015, 09:29 PM   #23
Robznob11
Robznob11's Avatar
Put a piece of cardboard behind it , use a sharpie , make a pattern, pick up some 16 gauge plate at hardware store, cut it out with a jig saw , clean it up with a grinder. Then weld it up with a mig. You could probably do it with a cheap flux welder. This particular spot is very ridged and will not warp very easy. Slap on some filler and paint . Wala
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-14-2015, 09:33 PM   #24
BigMike
BigMike's Avatar
I bought my fuel filler hole plate, side marker plates, stake pocket plates and he made A/C firewall filler plates for me as well. All precision laser cut and a great guy to deal with, he'd get my vote. If he doesn't have one up for sale just email him.
BigMike is offline   Reply With Quote
Old 07-17-2015, 05:05 AM   #25
Gravityamp
Gravityamp's Avatar
This is true , my dad showed me this too . The first time I ever saw him do it everybody scattered thinking this man was crazy . Even seeing it and being there never really quite prepares oneself for that first arc of a welder on fuel tank . Nerve racking but it get easier the more you do it lol
Thank you for posting , this brought back some great memories of superman ( my dad)
peace
69 GMC
400/400
2.5/4 drop from ECE
Gravityamp is offline   Reply With Quote
