Old 07-27-2015, 10:55 AM   #1
davidbakker
72 gmc timing
I have a 1972 gmc 1/2 pickup with a 350. I have changed the distributor to an hei with a 65,000 volt coil. The carb is an edelbrock 750 jetted down to a 650. It has an rv cam and I don't know the specs. What should I set the timing at?
davidbakker is offline   Reply With Quote
Old 07-27-2015, 11:13 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: 72 gmc timing
The timing for a GM 350 is usually around 6 BTDC. I wouold start at 12 and work on advancing the timing to get more performance, without detonation. The 750 carb jetted dwon to 650 is only leaning out the fuel/air mixture. That will still flow more cfm of air than a 650 CFM carb. You may have some stumbling issues with that setup on the carb.
Frank
Old 07-28-2015, 08:49 PM   #3
swamp rat
swamp rat's Avatar
Re: 72 gmc timing
Anywhere from 12 to 8 is probably where you will end up, just make sure it dosn't detonate when your accelerating, or want to diesel when you shut it off. i ended up around 10, i have a mild cam and about 9-9.5:1 compression.
If it does stumble make sure you have the accelerator pump rod in the closest hole to the pivot point. this gives a quicker dose of gas to the circut.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-28-2015, 09:05 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 72 gmc timing
To add... also open up your spark plug gap to .045 when stepping up to an HEI.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
