Old 08-22-2015, 03:00 PM   #1
Jeepers Creepers
What's up with this 1962 steering wheel?
I need to pull the wheel off my 62 to fix the turn signal. I have a steering wheel puller, but I don't see a way to attach it. Do those three screws need to come out or no? I'm hoping no because they're those ding-dang clutch head screws and I don't have a screwdriver for them. Ideas?
Jeepers Creepers is offline   Reply With Quote
Old 08-22-2015, 03:16 PM   #2
Boedean1981
Boedean1981's Avatar
Re: What's up with this 1962 steering wheel?
Yes you will have to take those 3 screws out unfortunately.
Boedean1981 is offline   Reply With Quote
Old 08-22-2015, 03:20 PM   #3
Boedean1981
Here's a quick pic of it too
Old 08-22-2015, 03:34 PM   #4
Jeepers Creepers
Haha! Thanks for that. I see those blasted screws in the picture. I couldn't get my dimmer switch off because of those same screws.
Old 08-22-2015, 03:36 PM   #5
Boedean1981
I believe they're like 1/4 inch Allen.
Old 08-22-2015, 06:42 PM   #6
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
they are called "butterfly", or "clutch head" a special screw driver. gm used those screws up until about 63... sometimes you can use a flat blade-straight edge- screwdriver that is the exact size to get them out, but be careful not to strip them! whenever I can I then replace the screw with the later models' Phillips screw.
Old 08-22-2015, 08:27 PM   #7
Jeepers Creepers
I got one of the dimmer switch ones off with a flathead but the other was already stripped. I didn't want to try it on the steering wheel so I'm ordering some clutch head screwdrivers. Thanks for the tips guys.
Old 08-25-2015, 08:20 AM   #8
Paul Y
Go and buy a cheap screwdriver bit set that includes a selection of clutch head drivers. I bought a 100 piece set for less than £10 ($15) recently.
Well worth the investment
P.
Paul Y is offline   Reply With Quote
Old 08-25-2015, 08:25 AM   #9
Jeepers Creepers
P.
Picked up a clutch-head set on Amazon for $10, should be here today and I can get this thing off. First time I'd ever seen one of these screws (my first project was a 1971 Caddy coupe, no clutchheads there).
